Lexar Professional High-Speed 2GB Secure Digital Memory Card Logo
Posted on May 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My laptop(dell) not DETECT lexar 2 GB SD(MULTI-USE).
John Waters
Level 2:
Sergeant:
  • Expert 251 Answers
  • Posted on May 28, 2011
John Waters
Expert
Level 2:
Sergeant:
Answers
251
Questions
0
Helped
39897
Points
702
My first item to Trouble shoot i think would be your media card reader, check in your device manager to see if there are any conflicts in the driver or if a driver is even installed for it. if there is a conflict, go to your pc manufacture website go to support , drivers an download the card reader and reinstall. Also is there any data on the card? and if not has it been formated yet?
My MacBook Pro OS X 10.9.1 won't read my Lexar Professional 800x 8 GB Compact Flash UDMA 7.
You can try using a file recovery software like Bad Copy Pro 4.10.125. It works well for me.
1helpful
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
I recently bought the vivitar 7024 and bought an sd card lexar multi use 4 gb. For some reason when I take photos and try to look at the pics it says no file exist. But when I take the sd card out and I...
Apparently, you have pics on the camera's internal memory. Your card won't work until those pics are gone. Here's how...with no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work.
I have a vivicam 5195 i am trying to format the memory card .the card is a lexar multi-use 4 gb sdhc . how do i unlock the card ?
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
7helpful
Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
2answers
What does error code 00400 mean
Moultrie told me they could not fix the camera. I removed the Lexar 512 SD card and re-ran the test. The test passed and the camera worked. I replaced the Lexar SD card with a Cannon SD card and reran the test. The test passed and the camera works. I put the Lexar SD card and got a 00400 error message. Change SD cards. It fixed the problem for me.
2helpful
2answers
I purchased a 2 GB SD card for my Kodak Easy Share C330 camera. This 2 GB SD card will not work. I was told that this C330 Camera can only take a 1 GB SD card. Is this correct? If it is not correct what do...
Although the manual doesn't specifically say the maximum capacity, looking at their accessories website only sells 1 GB cards for the camera. This tells me that the maximum capacity is, indeed, 1 GB which is not an uncommon occurrence.
Lexar Platinum II 4GB sd card won't work on my Polaroid PDC 3070
That card is not compatible with that camera. It's too large for an older model like that. Backup the card's contents and format it. It should work in newer models but probably not the PDC 3070.
Not recognizing 2 GB SD card.
sure..go back and get drivers for that SD card(from maker of it(not listed here) and you might get lucky.
check your computers warranty here 4 FREE
Lexar 4 GB Jump Drive
check for the USB drivers Of the Laptop.
Could be problem with the Laptop USB Controller Driver.
Top Lexar Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
