1. Manually turn on the component you want the remote to control.
2. Press and hold the component key (TV, VCR•DVD, SAT•CBL) you
wishto program. The illuminated ON•OFF key turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the illuminated ON•OFF key blinks four times,
and the process is exited.
3. While holding down the component key, consult the Code Lists for the four-digit code that corresponds to your component's brand and use the number keys (0-9) on the keypad to enter it.
While you are pressing the numbers, the illuminated ON•OFF key turns off.
4. After the fourth number is entered, the illuminated ON•OFF key turns on. At this time, release the component key. If the illuminated ON•OFF key turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry.
If you enter a code number that is not in the Code Lists or you do not follow all of the steps for Direct Code Entry,the illuminated ON•OFF key blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 2.
SOURCE: procedure to code in for rca312w remote to ge televsion
Turn on the TV, press and hold down the TV key, while holding down the TV key enter one of the four digit codes, the LED light should go off, if not, repeat the steps using a different code....hope this was helpful...
