Panasonic KX-TG5632M Twin Cordless Phone Logo
Posted on Feb 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set the date and time on the answering machine of my my Panasonic cordless phone model kxtg5632. I have a lot of power outages and every time I have one the date and time falls off the answering machine. What do I have to d to reset the correct date and time the message is left?
Terry
Level 3:
  • Panasonic Master 11,377 Answers
  • Posted on Feb 16, 2018
Terry
Panasonic Master
Level 3:
Answers
11377
Questions
Helped
4625707
Points
152765
5 8 GHz Expandable Digital Cordless Answering System with Two Handsets
Possible issue if you have Caller ID:
Why does the date and time change automatically after I have programmed the date and time on my phone?
If you are subscribed to Caller ID from your phone company, the unit's date and time setting will be automatically adjusted when caller information is received. If you do not wish for this feature to work, press [MENU] [#] [2] [2] [6] on the handset, then press [0] to select "Manual" and press [SAVE]
ftp://ftp.panasonic.com/telephone/om/kx-tg5631_en_om.pdf
Page 21 - setting date and time in manual at link above.
5 Related Answers
Eudice Spitz
  • Posted on Dec 17, 2008
SOURCE: Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
Anonymous
  • 18 Answers
  • Posted on Jan 10, 2009
SOURCE: panasonic kx-tg2740 cordless phone - how to change message?
  • Step 1Begin the recording process by first locating the "Change" button on your answering machine. This button initializes the answering machine for adjustments to the settings of the various features.
  • Step 2:Locate the microphone on your answering machine and lean towards it until you are about nine inches away.
  • Step 3:Locate the "Annc" button. Press and hold the "Annc" button until it beeps. Begin recording your message.
  • Step 4:Watch the message window while you are recording your message. It keeps track of how much time has elapsed since you began recording. You can record a message that is up to three minutes long.
  • Step 5:Locate the "Stop" button and press it when you have finished recording your message. The answering machine will play your message back at this point. If you are not satisfied with your message, repeat the steps to record it again.
  • Step 6:Press "Annc" if you want to listen to your message again.
i found this i hope it helps
Anonymous
  • Posted on Mar 03, 2009
SOURCE: panasonic answering machine not working
We had the same problem. Unplugging the unit and restarting it again solved the problem.
Anonymous
  • Posted on Apr 15, 2009
SOURCE: Good Evening! I would like to have some assistance in regards to the Panasonic Cordless Phone Model No.KX-TG1033C. Here's my concern: Set Date & Time My boyfriend has given me the above-mentioned phon
Hello
Please note that I have not received a reply to my question. Also the product in question is the Panasonic Cordless Phone Model No. KX-TG1033C and NOT KX-TG1032S as posted on my request.
In any case I still would like to know how to cancel and delete my profile.
Thank You
Montsie
Anonymous
  • Posted on Jun 19, 2009
SOURCE: digtal answering machine not working.
I don't know yet if this is a resolution, but I'm going to try this tonight. Unplug all bases and remove all batteries from all handsets -- leave this overnight.
Here's the history of my problem. I rec'd this phone for my birthday. 3 weeks in, power went off in my building and answering machine part stopped working. I took it back to the store, and they gave me a new one. 4 weeks in, another power outage and I have the same problem. I called Panasonic, and they told me to unplug all bases and remove the batteries in the handsets for 'a few minutes' to reset the units. I waiting 10 minutes, and replaced all batteries and plugged in all the bases again. No luck, answering machine still did not work. I noticed, however that the phone did not reset as I still had all my phone numbers and caller id history.
I called my brother who is an electrician, and he advised me that the base has a 'capacitor(sp?)' and it will probably take a few hours for it to 'drain' so the phone will reset itself. His suggestion is to unplug all the bases, remove all the batteries and leave everything OVERNIGHT. By that time, the power store in the base should hopefully be wiped out and the phone should reset like new. I will try this tonight and let you know if this works.
To set date and time on answering machine of a vtech cordless phone
Now that you've finally gotten around to specifying the model of your phone, follow the instruction on page 14 of the CS6429-3 manual.
1helpful
Seting time and date on answering machine of cordless phone
I would like to change the number of rings before answering machine picks up. How do I do that? I have a panasonic cordless dect 6.0 phone
I had the same problem but couldn't figure it out either ..... UNTIL, I changed the date and time (which was very old, actually Sept/2007) to the current date, year, time, am/pm, etc.
After I changed the date, time, year, etc. my phone went back to its normal default of 3 or 4 rings & then the answering message plays.
Hope this helps!
11helpful
Model 25942EJ3-C
Try this:
1.) Make sure the answering system is on.
2.) Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
3.) Press key (8) to enter Time/Day set menu using the handset.
4.) To set the Hour, key in (00)-(12), like 08 for 8 o'clock.
5.) To set Minutes, key in (00)-(59), like 15 for 15 minutes after the hour.
6.) To set AM/PM, press the CALLER ID-VOLUME up or down buttons.
7.) To set the day of the week, press the CALLER ID-VOLUME up or down buttons.
8.) Press #PAUSE/ringer button to confirm the setting.
Hope this helps you out! Hal
WE HAD POWER OUTAGE/NOW WE HAVE THE LETTER A--WONT GO AWAY
Your machine is set to "Announce" instead of "Answer" mode. The announce mode merely plays an outgoing message but does not record any incoming messages.
Since you neglected to specify the model of your VTech 5.8GHz cordless system I can only suggest you enter it into the search box here to download a copy of the manual to learn how to switch modes.
2answers
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
