Cisco Linksys E2000 Advanced WirelessN Broadband Router Network Routers Logo
Posted on May 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant connect my ps3 to the linksys E2000..how do i in full directions connect the ps3 using wireless internet.do i have to get a code?
venugopal durairajan
Level 3:
  • Master 464 Answers
  • Posted on May 28, 2011
Master
Level 3:
Answers
464
Questions
Helped
194214
Points
1702
Just follow the instructions given in the manual of your ps3 to connect your gaming console to the linksys router. it will ask you to enter the code(wireless key). if you are not sure where the wireless key is you need a computer and an Ethernet cable to find it.
if you have entered a wireless key and still the connection fails, try changing the wireless channel, to channel 11 and the wireless setup from wi-fi protected mode to manual. if you are not sure how to do this, please reply to this post, i will give you the instructions !!!
Anonymous
Level 3:
  • Cisco Master 32,281 Answers
Anonymous
Cisco Master
Level 3:
Answers
32281
Questions
Helped
7913497
Points
102259
For instructions on setting up the PS3, Xbox, Wii, for a wireless/Internet connection. please click on this WEB link :-
http://fixhomenetwork.com/xbox-play-station-wii.php
Escribe your Linksys E2000 Advanced WirelessN Broadband Router Network Routers Problem Router has been working fine since initial setup almost a year ago. Turned on computer yesterday, and it would not...
Please check whether your computer's wireless connection enabled or disabled. If you are using windows 7 this information you can find in network sharing center. By accident if WLAN is disabled it can be enabled. Also power cycling the router may do the trick.
More drastic approach is resetting the router which I recommend to reserve as last resort. With information you provided the router seems to be fine and your computer wireless need to be enabled!
good luck!
How does the gateway2000 solo get the internet my son just buy this
what type of connection you have just try to connect the WAN port of Ethernet cable if u use this cable directly to connect your laptop to internet after that connect to router via wireless it will give you an option to configure the ssid and password for your WiFi follow instruction then you done u don't need to use CD for installation .other old method is to connect your computer to any port of linksys Router E2000 "not WAN " in the browser type 192.168.1.1 then enter put admin for both password and username go to setup make sure DHCP enabled WAN connection should be dHCP as well go to wireless choose manual then enter any name u like for your wireless go to security TAP under wireless then choose manual and the choose enable ,,,, encryption WPA2 enter any password you like save the configuration reboot the router make sure WAN port connected to your main internet it is ready to use should you need any help please contact me on my blog http://computernetworksupportindubai.com/
2answers
2helpful
3answers
Need Driver for the Linksys E2000 Advanced Wireless-N Router? Where can I download?
You can Find the Downloads Here
http://homesupport.cisco.com/en-us/wireless/linksys/E2000
Wireless laptop will cannot connect to the internet through the e2000 router. Wired connection works fine. Flash drive setup for wireless connection was also used.
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
There a great article at General Router Setup.
My acer aspire one netbook will not connect with my new linksys e2000 router.. It was fine with my former linksys router
If your former linksys router was NOT N but rather b/g, then the problem is likely that your new router is running N and must be reconfigured to run b/g instead of n on its wireless. The acer aspire one netbook's integrated WiFi is 802.11b/g and the only way to do 802.11n is by using a plug-in USB 802.11n wireless adapter. To manually configure the router's wireless for 802.11b/g or n...
1. Connect the netbook using an ethernet utp cat5 patch cable between one of the four RJ-45 LAN ports on the router to the 10/100 ethernet RJ-45 port on the netbook's left side.
2. Start a browser like Internet Explorer and enter IP address 192.168.1.1 (default for Linksys)
3. On the login window, enter admin for username and admin for default password, then click OK
(The password may be changed if the router's setup software on its CD has been run.)
4. On the Linksys Setup page, click the Wireless tab
5. On the Linksys Wireless page, for Network Mode, click v for drop menu and click BG-Mixed
The preceding is from Chapter 3: Advanced Configuration which starts at page 16 of the 59-page Linksys E2000 user guide/manual. If you are missing this manual, it can be obtained by clicking...
http://homedownloads.cisco.com/downloads/userguide/E2000_UG_USA_V10_NC-WEB.pdf
A final note: The easiest way to setup the router is to run its setup software on the CD that comes with it. If you want to do this with the netbook (which doesn't have an internal CD drive), an external CD drive would have to be plugged into one of its USB ports.
Internet lose on my wrt54g2
please reset the router
configure the router type ip address on the browser
may be 192.168.1.1
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
