Homelite 'Yard Broom' Leaf Blower Logo
Posted on May 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot find a replacement primer bulb for my Homelite UT 08110 yard broom blower
Anonymous
Level 3:
Brigadier General:
  • Master 3,301 Answers
  • Posted on May 27, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
3301
Questions
0
Helped
1013887
Points
10058
Check here, if you don't see it call them, they've had every one I've ever needed http://www.lawnmowerpros.com/homelite/homelite-primer-bulbs.asp Please rate my response
I have a Homelite UT-08110 Yard Broom Blower... when I got it, the fuel lines were rotted and brittle and only one was hooked up. how do the lines actually hook up?
The short line in the tank (about 1/2 inch in tank) goes to fitting just below primer bulb. The other line that goes to bottom of tank with filter attached goes to other fitting.
I need a primer for the carb and a fuel line going into the gas tank or maybe a new gas tank
They sell primer bulb and fuel line kits at Home Depot for like $6.99 or so...not sure if parts will suit your model, but they might. You would have to order the replacement fuel tank though or search for one on Ebay. You can also try:
http://www.ereplacementparts.com/
PRIMER BULB WONT PRIME
I would recheck the carburetor to make sure you put the diaphragms next to the carburetor and not the gaskets.
Please if it is not priming you may have the fuel lines hooked up wrong. Also check the fuel cap to make sure the vent assembly is there. If the tank is not venting, the tank will get a vacuum in it not allowing fuel to flow.
HTH
Good Day.
Leaf blower will crank only when spark plug is dipped in gas and re-inserted
fuel system needs to be cleaned, carburetor diaphragms and gaskets replaced, check fuel lines, filters, primer bulbs
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
1helpful
Reinstall the starter rope on a Homelite Model UT 08026 J.
Go to smalleng.com free video for just what you are experiencing.
Gas/oil ratio for a Homlite UT 08026H blower?
I USE SOME STUFF CALLED OPTI THAT WAY YOU ONE CAN FOR ALL YOUR 2 CYL STUFF ITS GOOD STUFF
1helpful
Plastic dome used to prime has hole
The primer ball can be bought at any local mower shop. Just ask for a primer bulb. Remove the screws (usually 2) next to the bulb and remove the plate around the bulb and it should pop right out.
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
