So I assume you have changed the batteries and made sure there isn't any corrosion on the contacts. If your mirror is flipping up but no shutter, it sounds like a bad shutter. Check the shutter from the back, then from the front behind the mirror. Look for abnormalities or residue. It is a great camera and uses standard batteries (!) but the 1/2000 shutter has a half life like any other SLR. If you are going to throw it out you may want to open the back and use a q-tip to drip a couple drops of 90% alcohol on the top and bottom (and sides) of the shutter. As a last ditch, I throw cameras or lenses in the toaster oven at 200° for 10 min. and retry (take out batteries and film). At the least it will kill any fungus at the worst it hardens some lubricants. It does make you feel like you are doing some specilized scientific work before you toss it in the trash.
SOURCE: nikon fg light meter
Try new batteries. If that doesn't help, the body likely has an internal failure in the electronics. It will almost certainly be less expensive to replace it than to have this type of problem repaired.
SOURCE: Don't know how to open door latch on nikon 35mm SLR camera
You haven't stated which model you have, but generally most SLR's open by pulling upwards on the film rewind crank (the knob on the left side of the top-plate as viewed from behind). If this doesn't work then add the exact model as a comment to my answer and I'll try to give you specific instructions for your model.
SOURCE: I have a Nikon N90s /film 35mm slr. I haven't
If the switches and contacts are dirty that would do it. If that happens the cost of service may exced the cost of buying a used one.
SOURCE: Nikkormat 35mm SLR light meter not working!
1) Clean the battery contacts and put fresh battery.
2) Open the top cover and clean the meter switch ( located and the wind cam )
3) Meter needle maybe stuck at the rest position. Remove the stopper and replace or clean.
4) If none of these help, check the meter cells and resistor band under the shutter dial behind the lens mount ( hard to do.)
SOURCE: how do I change the shutter speed on a Nikon EM
The EM doesn't really have a manual shutter speed setting. It does have a Bulb setting for long exposures and a 1/90 second manual for flash, but otherwise the camera automatically sets the shutter speed to go with the currently selected aperture.
Normally you would set the aperture and let the camera set the shutter speed. You can adjust the shutter speed by pressing the exposure compensation button for +2 stops. You can also adjust the exposure by changing the ASA/ISO setting.
If you need a manual, you can download one from http://butkus.org/chinon/nikon/nikon_em/nikon_em.htm
