SOURCE: Can't reset my walkman
hi gintys
NWZ-S515 | Sony Europe Customer Support Portal
any info above that will help you.
riz.
SOURCE: sony walkman nwz-s18f froze
I had this problem a few days ago and now my sony nwzs18f has different problems, the way i got it to charge back up was by using a usb charger that plugs into a socket rather than into your computer this should hopfully charge it back up and also it should unfreeze the screen.
hope this helps
SOURCE: fully charge sony walkman NWZ-E436F does not turn on power at all
well u might have gone wrong u should charge ur walkman for abt 3 hrs first use untill full appears and it is recommended that even if u dont plan to use u r walkman u should atlest charge the battery once a while for battery mentainance try to reset ur update the player firmware.or even then if it dont comes send it to sony or have a converstion with sony support
SOURCE: Fully Charged Sony NWZ-E436F Doesn't Turn On
did anyone ever get back to you on this? I'm having the same problems.
SOURCE: Is it possible to downloan
You can download a movie to your computer and then copy it to your player, most likely it won't play on your MP3 player unless the movie file is converted to a file format that suits your MP3 player.
http://www.fixya.com/support/r5874192-play_videos_mp3_player
