Question about TP-LINK 300Mbps Wireless N ADSL2+ Modem Router TD-W8960N
Error 045 when setup the modem with Win7 64 bit, connection to network failed.
    Scholar:
  • 134 Answers
What the problem? i'm also using this router...
how you setting the router?using wifi or LAN?
BEFORE THAT,
DOWNLOAD HERE
RUN INSTALLER FIRST BEFORE CONNECT TO YOUR ROUTER.
connect line rj11 to link dsl,rj45 to your pc/laptop.(dont use wifi to setup the router)
then plug the power and ON the wifi router.
After that, check light for ADSL, WLAN INTERNET AND PORT(1 OR 2 OR 3 OR 4) IS BLINK
..IF light is okay and blink, then you can setup the utilities.
Is easy. TP-LINK get ready with software that you can setting the router as like professional with the secure encryption. For receiver I'm preferred you using tp-link also. Then you can use QSS function only just click button QSS..
Posted on May 27, 2011
  • 1 more comment
  • MOHD NURULAZMI SULAIMAN
    Hello sir, How about your router? Is okay?
  • albert_lee May 29, 2011
    i found the problem. when land line is engaged then internet will be disconnected.
    any help?
    sorry, i mean when land line is engaged, then internet is ok, when land line is drop, then internet is disconnected.
6ya staff
SOURCE:
Connection failed
This is a message from the AVR2312CI attempting to connect to the Internet through it's local area network Ethernet socket. Turn this feature off in the setup section if you do not need to connect. If you do want to connect, make sure you have a good connection to your router and, if necessary, make sure your security software is not blocking the connection. If that fails, turn off modem, router(s) and amplifier then switch on in the order:
modem,router(s) and finally your AVR2312CI.
That should solve your error message.
Regards, Don.
May 31, 2014 | Denon AVR-2312CI
When i try to use Internet with my sony XBR-55HX925 tv, it displays: error de red 1106...Plase, what can I do for solving this problem ? Thank you so much.
Error 1106 is an indication that the Domain Name System (DNS) was unable to resolve. Follow the steps to check the Internet connection:
  1. Check the Network Connection.
    1. Using the supplied remote, press the Home or Menu button.
    2. Select Network Setup .
    3. Select View Network Status .
    4. Select Check Connection .
    If any of the connection settings fail, verify that the TV is properly connected to an active Internet connection.
    Follow these steps, if the error continues to appear:
  2. Unplug the TV and wait 60 seconds.
  3. Power on and off all of the networking equipment, including the modem and router.
  4. Allow the Networking equipment to reset after powering them of and on. Test that the connection is active by using a computer.
  5. If the issue continues, wait and try viewing the content later.
Aug 14, 2011 | Sony KDL46HX800 46 in. 3D LCD TV
Have connected wii to cable via cisco asa 5505 box. getting error code 52020. have restarted comcast modem to no effect.
Error Code: 52020 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
    Connecting directly to a modem:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
    Connecting to a router:
  1. Ensure that an Ethernet Cable is running from the WAN or Internet Port on the router to the modem. Power cycle the modem by unplugging it from the electrical outlet, waiting a moment, and then plugging it back in.
  2. Power off the Wii console, and insert the Wii LAN Adapter into one of the USB ports on the back of the Wii console.
  3. Run an ethernet cable from the Wii to a numbered port on the router.
  4. Power on the Wii console, and run a connection test through the Wii console's online settings.
  5. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's settings on your PC:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these as they're listed into the "Manual Setup" of the Wii console's internet connection, except for the IP address. The IP address needs to be different. Add 10 to the IP address and use that number in the Wii console's settings.
you can also visit this site for more information about your comsole tnxx please rate me if this help you...
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52020&system=Wii&locale=en_US
Aug 09, 2011 | Nintendo Wii Console
I have internet through cable.it runs through the sb5101u surfboard motorola modem. i bought the lan adaptor to go to the wii, for netflix, but it won't connect to the internet. error code 52020
Here is the solution from nintendo:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input theseexactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
May 05, 2011 | Nintendo Wii Console
Bought a pre owned wii and im trying to hook it to the internet but it says error 52020
4. If the connection test fails, try a Manual Setup with the Wii console, using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
Mar 15, 2011 | Nintendo Wii Console
I have a samsung tv , and im setting up my INTERNET@TV , it ticks off everything but the Gateway Ping ! Please Help
If the Gateway Ping test fails, then your TV is not communicating properly with your Router or Modem.
To resolve this, follow these steps:
  1. Power off your TV, Modem, and Router.
  2. Unplug the power for your Modem and Router.
  3. Make sure the ethernet cable is securely connected to both your TV and your Router or Modem.
  4. Plug in your Modem and turn it on.
  5. Plug in your Router and turn it on.
  6. Make sure your IP Address information entered into the TV during the Network Setup matches the information from your Router or Modem.
  • If you are using an Automatic Setup (most users), skip this step.
  • If you are using a Manual Setup (advanced users), contact your network administrator to determine what the correct IP Address information is.
7. Run the Network Test again.
  • If the Gateway Ping test passes, but another test fails, click here to go back to the list of Network Tests.
  • If all tests pass, the TV is successfully connected to your network.
  • If the Gateway Ping test fails again, see below....
If the Gateway Ping test fails again, there may be a problem with your network setup. To determine if there is a problem with your network, follow these steps:
  3. Connect your ethernet cable directly to the TV and Modem.
  5. Power on the TV and run the Network Tests again.
  • If all tests pass successfully, then there is a problem with your Router setup. Contact your network administrator or router manufacturer for information on setting up your network.
  • If all tests do not pass successfully, there may be a problem with the TV. Connect another device (such as a Computer) directly to the modem.
  • If the other device connects to the internet, then the TV will require service. Click the Create online service request button below to have the TV repaired.
  • If the other device does not connect to the internet when directly connected to the modem, then there may be a problem with your modem. Contact your Internet Service Provider for help on troubleshooting your modem.
(from Samsung support)
Hope this helps. -Sa_Les_Ski
Feb 28, 2011 | Televison & Video
I'm trying to connect my Wii to the internet with the "Nintendo Lan Adaptor". I plug the ethernet cable at the back of my cable modem (motorola SB5100). I get errors 51420, 52020 and 50299 Help...
Sep 13, 2010 | Nintendo Wii Console
Connection Comcast router to wii
Error Code: 52021 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
Mar 13, 2009 | Nintendo Wii Console
Okay,i manually setup an internet connection on my PSP but for some reason when i try to get on the internet with it it says:Communication with the server failed. A DNS error has occured (8041040F). I dont...
From what I understand you are trying to get online with your playstation and to do so you want to share the internet connection with your computer but two things you mention make me believe the problem might be one of these two solutions.
First in order to start an online gaming session, at least on Xbox live, you need your own DNS which is a Domain Name Service and unique address associated with your gaming device. Since your computer already is using that unique address which you put in manually it comes back as an error. You don’t mention if you have a router or not but I will assume you do, if this is the case you need to set up your playstation to have the network setup complete automatically which will enable your router to supply the playstation with another address which will be unique to it thus no error when trying to connect to a gaming session. If this fails on the automatic setting you will need to reboot the modem that connects your computer to the internet and then reboot your router with both the computer and the Playstation connected to your router at the same time, the modem will then supply the router with a new DNS and then the router will supply both the computer and the Playstation with a new DNS and its own unique address. Once the router has rebooted get online with your computer to check to see if your router completed its tasks. I f you can get online with your computer then now go back into the Playstation setup and make sure all of the network parameters are set for automatic such as DNS, no proxy, ect.. This should get you online unless you also have a firewall problem.
If you do not have a router, only a modem from your internet company, then you will need to disconnect your computer from the modem, no sharing, connect your playstation directly to the modem, then reboot the modem. All network settings still need to be in the automatic mode in Playstation to work properly. If that still does not work that would suggest your IP gives you a static address and you will need to call them to get your network logon info and then with that info in hand set the playstation up manually with that info.
Aug 27, 2008 | Video Game Consoles & Games
3Com 3824
Download free version of HyperTerminal for Vista : ftp://ftp.hilgraeve.com/htpe/htpe63.exe
Make a new connection :
connect using COM1 (depends of your configuration)
19 200 bits/sec
8 data bits
No parity
1 stop bit
No control of flux
And push enter twice to display a "Login:" prompt.
Connect using default user/passwords : http://support.3com.com/infodeli/tools/switches/ss3/management/ug/setup.htm#13131
Regards,
AstroMan
Jan 14, 2008 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
TP-LINK 300Mbps Wireless N ADSL2+ Modem Router TD-W8960N Logo
3,103 people viewed this question
Top TP-LINK Computers & Internet Experts
 Mike M
Mike M
alex metro
alex metro
Pamela Bates
Pamela Bates
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
