Dear
You have upload the firmware of ML-1640, which is not possible. Try to upload ML-1666 firmware fix. You can also try covering a tape on the chip contact area only.
Thanks.
Samsung printers such as ML 1640,ML 2245 and SCX 4300 have a toner page count embedded in their firmware. This is the reason that once you refill your toner after it has run out,the printer still doesnt print and says toner is exhausted.
After you've refilled the cartridge,you'll have to reset the toner count also to zero...to do this,download the firmware here.
ML 1640Ml 2245 and SCX 4300 are not available on Samsung support site.
You will need to google it and you may find it in torrents.
run it and it will reset your toner count to 0...you have to do this everytime you refill your toner.
Another solution is to open the backside of ML 1640 and ML 2245,locate the chip 93c66 and short pin numbers 1 and 4 and turn on the printer for a second.It only works in some cases though.
Here I will post u an link with some solutions. http://www.fixyourownprinter.com/forums/printer/59558 http://www.fixme.ro/Fix-and-Solutions/samsung-ml-1640-counter-reset.html There is an fimware fix. u can find it there. Work for old versions.
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
pls give the patch file for reset the samsung monochrome printer
ml-1640 printer.so printer count reset problem.give me a service
support from your side.
