Televison & Video Logo
Ray Hanks Posted on May 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi. I have an old Sony Wega 32" LCD TV which I
Anonymous
Level 2:
New Friend:
  • Expert 53 Answers
  • Posted on May 26, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
53
Questions
0
Helped
12587
Points
172
Ok it depends on the wall mount but this is the basic idea of it. make sure there is at least one other person to help you.
1. Make sure everything is off and unplugged from the tv. 2. If you have cables holding your tv to the wall remove them. 3. there should be securing screws at both sides of the arms attaching the tv to the wall. loosen them/ remove them. 4. lift and pull the tv away from the wall. have a friend help you. 5. remove the screws and bolts from the tv and the wall mount and you should be done.
If this doesn't work, find the manual for the wall mount. if you need help or additional tips put them in the comments. Thanks
Testimonial: "Thanks Thinkingmonk, you're a star."
How to attach wall mount to a Sony Bravia 32" TV
You need to be careful here. Unless you are very handy, the TV could come crashing down to the floor if not done correctly. Depending on how much you paid for the TV, I would hire a trained individual to do this.
Hi, I am perplexed. I have a Sony KD-FS32170 model television. I just bought a Panasonic receiver to attach to my Sony along with four Bose speakers I already had. Unfortunately, I discovered there is no...
Hi
This tv should have one or two 21 pin scart connector;s on the back, using a scart to rca (phono) adaptor you should be able get audio out, and this can be connected to your sound sty. note the level will be fixed not dependant on the volume setting. Hope this will help regards Derrick
2answers
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
1helpful
2answers
My Sony WEGA kv-32" TV
The "D" board is the main circuit board assembly containing most of the set's power and deflection circuitry. It's the board that typically causes most of the problems because there's so much on it. Unfortunately, this board is no longer available from Sony as a part, and must be repaired to the component level. Many shops don't want to (or can't) get into that depth of repair, so they quote a high price on board replacement. There is no single part you could order to repair this board yourself, I'm afraid. There are some companies in the business of repairing boards, but you're still looking at $200 to $300. With the price of a 32-inch LCD set now around $300 to $400, there's no point in trying to fix a TV when it's just a few dollars more for replacement.
Sony Wega tv
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
4helpful
2answers
I need a table top tv stand for my sony kdl 40w3000. perhaps you mounted your screen on the wall and so do not need your old tv stand? please get in touch! i have the money ready!
hi here is a link to the stand for your tv at sony parts store >
http://www.partstore.com/Part/Sony/Sony/KDL40W3000/Sony/Sony/A1257997A/New.aspx
please dont forget to rate me i need a few more for my badge thank you and if you need anymore help let me know..
1helpful
Sony Tv turns itself off after 5 seconds...blinks 7 times?
Had the same problem. Unplug from wall for 36 hours and then it works.
Hp Sydney Aus
28helpful
4answers
Sony FD Trinitron Wega degasses and goes to standby, blinking 6 times. Worth reparing this almost seven yr old set?
Rather get a quote first , then you can decide whether you need a new set or not ?
After SONY sets work like dogs especially if you use them alot. Think about a replacement cost ?
I would say get a quote before you decide.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
