Hello
It is very difficult to get the universal remote code for Apex Digital. I found only one remote control that has codes for Apex; and is Comcast Ondemand Custm-3 Universal remote control. The codes for Apex TV are
0748, 0765, 0767
The proceedings to enter the code will be available with its manual OK.
SOURCE: unlock apex tv model # AT2702
try this manual;
[PDF] AT M C T
On the remote try pressing the ( F ) button and the mute button at the same time on your remote control.
Here's the link for the 2402s manual:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=4db1185db9d3369
Pass Code Menu
This menu allows you to change the access code for the Parental Guide
functions of the TV set. Pressing the “Menu” key when Pass Code
Control is highlighted. This will turn on or off the Pass Code function. With
the Pass Code function ON, you can also change the Pass Code. Use
the down arrow key to highlight “Pass Code,” then enter the new Pass
Code using the numeric keypad. Press the left arrow key when finished.
1. The factory default pass code of 6688 is also the override code, in case
you forget your new pass code.
2. The factory defaults have TV-MA and MPAA-X ratings blocked .
Hope this may help you
DON'T FORGET TO RATE:
Please try this:
On the remote hold down the (F) function key and press mute.
SOURCE: Apex AT2702 27" color television under scan
well most of the modern tv today doesnt have vertical hold anymore.
this
symptom is caused by a trouble in the IC integrated circuit or the
vertical oscillator circuit. let the service guy do the job if u dont
know anything about this. good luck!
