My rv refrigerator does not cool properly. freezer works fine. problem is the same on lp gas or electric. On highest setting refrigerator will not cool below 47 degrees. it is norcold model 1122 i beleive. i have had thermister replaced and circuit board in back og refrig still not working right/
It works for a while then stops but it works less than more
You can bypass the controls and hook 110 power up to the both heating elements (they should be hooked together already) to test for sure, let it run for 8 hrs, if it cools right than it is a control problem. but more than likely you have a bad cooling unit.
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
no power when plugged in. need repair information.
can you tell me the cu.ft. of Norcold N611L rv refrigerator
Checked all fuses and circuit breakers and all are OK.
Refrigerator works with electric power but won't light with gas
norcold model #N611LT
Whirlpool refrigerator model GB2SHKXKQ00 will not cool below 52 degrees
