Midland 75-822 40-Channels Handheld CB Radio Logo
Posted on May 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Midland 75-822 that I run off adapter power all the time. How do I turn off the battery save function? With it pulsing the power on and off I miss the firt syllable when someone transmits.
Iron
Level 3:
  • Master 3,018 Answers
  • Posted on Nov 03, 2011
Iron
Master
Level 3:
Answers
3018
Questions
Helped
1670450
Points
10301
  • Their is no power save mode on this CB in the terms I think your thinking of. There is a high and low power that deals with how much power the CB puts out when transmitting that will make your battery last longer but this would have no bearing on the issue you are having.
  • If you are using a power cord all the time then remove the batteries from the CB until you need them. There are two thumb clips you pull down on and pop the compartments off (one is for rechargeable and one is for regular Alkaline batteries).
  • If the CB is actually powering on and off you have a power feed issue such as a bad connection, a failing power feed socket, a weak inline fuse on the power cord about to blow or something internal is malfunctioning.
  • Hope this helps.
Wireless power does not work
You may experience random connectivity issues when you connect a Windows-based mobile PC to certain Wi-Fi "hot spots." These connectivity issues include the following:
  • The wireless network connection is dropped.
  • You experience poor performance.
You experience these issues if the computer is running on battery power.
Note You may also experience these issues when you connect a Windows-based mobile PC to a wireless access point (AP) in a small office/home office (SOHO) environment or in an enterprise environment. Cause This issue occurs if the Wi-Fi hot spot uses wireless APs or routers that do not support the 802.11 power save protocol.
This issue occurs because of the power saving features that are included in Windows. The default power plan that Windows uses for a mobile PC is the Balanced power plan. The following is true for mobile PCs that are configured to use the Balanced power plan:
  • When the mobile PC is plugged into a power source, the wireless network adapter is configured to use Maximum Performance mode. This turns off 802.11 power save mode.
  • When the mobile PC is running on battery power, the wireless network adapter is configured to use Medium Power Saving mode. This uses the 802.11 power save mode.
When an 802.11 wireless network adapter that is set to use power save mode wants to enter a sleep state, the adapter indicates this intention to the wireless AP. The adapter does this by setting the power save option in its packets or in the 802.11 frames that it sends to the wireless AP. In this scenario, the following behavior should occur:
  1. When the wireless AP receives the frames that have the power save option set, the wireless AP determines that the client network adapter that sent the frames wants to enter a power saving state.
  2. The wireless AP then buffers packets that are destined for the client network adapter.
  3. When the radio of the client network adapter turns on, the client network adapter then communicates with the AP to retrieve the buffered packets.
This behavior enables the wireless network adapter to use less power and to wake up periodically at the correct time to receive network traffic from the AP.
If the wireless AP does not support this feature correctly, the wireless AP continues to send packets to the client network adapter even if the client network adapter radio is turned off. Therefore, these packets are lost. In this scenario, the symptoms that you experience may vary depending on the phase of the wireless connection in which these packets are lost.
Pulse noise
Not sure what you mean. Can you give more info?
1helpful
Hp probook 4520s charging time more brightly .battary off time darknessly
Laptop screen is normally brighter when it is connected to the charge adapter. When the laptop is running on the battery it is usually a little dimmer to save battery power, you can adjust the screen brightness even on battery power. To adjust the brightness hold down the Fn key and press one of the function button keys it maybe the F7 or F8 key it will have a symbol on the key to indicate the screen brightness.
Turn off after a few hours
If the TV turn itself off then perform the following steps:
(i) Check if the Sleep timer is activated.
(ii) Check if the Parental Guide prohibits viewing during that time and/or limits amount of viewing time per day.
(iii) Check the batteries on your remote, low battery power may cause random signals from the remote.
(iv) Disconnect all the cables from the TV then reconnect them after a few hours.
(v) Ensure the power cord from the TV is directly connected to a functional wall outlet.
(vi) You may also try resetting the TV to the original factory settings by pressing the Reset button on the remote control supplied with the TV when in Menu.
The following is the information indicated by the blinking patter of the standby/timer lamp on the TV:
2 times : Power does not come on.
Load on power line shorted.
3 times : The TV has entered standby mode.
4 times : Has entered standby state after
horizontal raster.
Vertical deflection pulse is
stopped.
Power line is shorted, or
power supply is stopped.
5 times: No raster is generated.
CRT Cathode current detection
reference pulse output is small.
6 times: No picture
9 times : No sound
Furthermore, the TV is equipped with a self-diagnosis function that you can use to determine whether the issue is related to any hardware malfunctioning. Perform the step given below to run self diagnosis:
Quickly press the remote command button in the following order from the standby state.
Display -------> Channel 5 ---------> Volume -(minus) --------> Power ON.
If the Self Diagnosis display numeral "1" for any parameters then a fault has been detected and service will be required.
wish u good luck!!!!!!!!!!
3helpful
Need to make sure programmed
Program the Midland 74-109 Weather Radio
a) Turn unit on. Extend the antenna. Adjust volume up slowly; Do you hear anything? If not, try replacing the 9 volt battery with a fresh one, in the accessible battery compartment underneath the unit. Repeat above steps.
b) If no sound is heard, turn unit over and look for "WEATHER" slide switch on bottom. With unit on & volume adjusted to comfortable hearing level, slowly slide switch down (or up) through various frequencies [1)162.550, 2) 162.400, 3) 162.475, 4) 162.425, 5) 162.450, 6) 162.500, 7) 162.525] until voice transmissions are heard. This should be the closest National Weather Service (NWS) broadcast for your area. Check the NWS website at http://www.nws.noaa.gov/nwr/nwrbro.htm for your state, click on the state name, and look for the site name or site location nearest you. The frequency for that site should be the strongest, and appropriate for your area.
c) You can set the alert tone, for special weather alert broadcasts, on the bottom of the unit on the slide switch marked "ALERT". Set the switch to the desired type of alert: 1) LED [LED on top of unit (marked ALERT) lights up when alert is broadcast-no siren tone/alarm is heard] 2) LED & ALARM [LED lights up and alarm/ siren tone is heard] 3) VOICE [LED on top of unit lights up and voice broadcast is heard, only; no siren tone/alarm is heard].
d) Be sure to press the "ALERT" button on top of the unit and leave the volume at a comfortable listening level to hear weather alerts for your area (Alert LED on top of unit lights up to show Alert function is active). You can test the present volume level by pressing the "TEST" button. Be sure to press the "ALERT" button again after listening to the volume level to re-set the Alert function. You can listen to weather broadcasts anytime, by pressing the "WEATHER" button. After listening, be sure to re-press the "ALERT" button to reset the Alert function.
e) 9 volt battery life should last about 6 to 7 months, depending on how much unit is used an number of alerts received. Replace battery every 6 months, or when you replace your smoke alarm battery, or at beginning and end of daylight savings time. A 12 volt AC adapter to replace the battery, can be used. One should have been supplied with unit. If not, a replacement can be found at Radio Shack.
f) This should complete your Midland Weather Alert Radio Model 74-109 programming.
2answers
WR-100 WEATHER RADIO
The WR-100 is slightly smarter than the average basic weather radio and therefore has a fair amount of programming loaded into it's firmware. (for good or bad)
It's not impossible for a power failure or spike to cause the internal processor to become confused every once and a while.
You may need to perform a full reset.
Remove the power adapter, remove the batteries and then press and hold the "WEATHER / SNOOZE" bar to bleed off any remaining charge in the capacitors and then plug the AC adapter back in.
Install fresh or known good batteries.
You've now essentially "rebooted" your radio and hopefully it will now function correctly again.
The only drawback is that you will have to reset any custom programming. As nifty as SAME technology is, I rarely use the function.
PT
3helpful
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Turn on
Have you checked your power adapter with a digital multimeter? Maybe run it by your local radioshack or computer super store if you dont have a DMM and see if someone can check the voltage on it. Maybe your adapter died, then the laptop was running on battery until it went dead.
Another quick check, remove the battery all together. Plug in the ac adapter... does it turn on? does it show any lit led's indicating it is plugged into the wall? try wiggling the connector at the jack on the laptop, does that light any led's or cause power to be restored?
Acer will not start up properly; "pulsing" On and Off
Hi Melody, Try removing the battery with the AC unplug for a couple of minutes (an hour preferably). Try with just the AC adapter only with no battery and see if it works; try with the battery only and see if it works, try with both the battery and the AC adapter and see if it works. If none of the above will make it work, then you have probably a hardware issue or BIOS power saving issue. Post back results of the 3 tries and will figure something else. Good luck and kind regards.
Top Midland Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
