SOURCE: Mitsubishi WD 52525 lamp replaced, no picture, red light
You have to take the TV apart. Pull the electrical chassis out and look for bad electrolytic caps on the boards. The red LED probably means the 2 - 3300UF caps on the power supply board are bad. You can tell if they are bad by the fact that their tops are puffed up and they may or may not be leaking brown fluid. Compare them against the other caps on the boards and you will see how they have flat tops.
BUT before you take the TV apart you can check the error codes by pushing "menu" and "Device" at the same time and holding for about 10 seconds. The status light will blink two numbers. ex. one flash pause two flashes is 12 Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
or use this table -
You can buy replacement caps from Mouser electronics online. There are plenty of solutions detailing how to do this already posted.
SOURCE: My wd-Y57 comes on no picture, but does have
Read comments from others on your web site and figured it must be the lamp.
Ordered a new one and that fixed the problem.
Thanks!
Charlie
SOURCE: Mitubishi WD 62725 - Ballast Problem??
Could be the FMT pcb or the Dm pcb board you should check the caps on them and replace any faulty ones.
