Lands Phones Logo
Posted on May 25, 2011
Security code or reset code for nokia 5330-1d tv edition?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1020
Points
Anonymous
Level 1:
  • Posted on Apr 26, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1020
Points
0
How to reset security code for nokia 5330
  • rosinah
    rosinah Dec 30, 2013
    How to reset security code for nokia 5330.i forgot my code. please help me..
  • GABRIEL KOLAWOLE
    GABRIEL KOLAWOLE Nov 07, 2017
    i locked my nokia 5330-id by a security code and i dont remeber.how can i unlocked it?
Lock with security code
Hello..
Try this code...
To reset security code:
*#7328748263373738#
edit: to check your IMEI No. *#06#
Security code
Hi mpho,
If you have not changed the security code of your phone then it would be having the default security code.
For Nokia the default security code is 12345
If it does not work you can also try 00000
Thanks
Vote plz
1helpful
I forgot my security code,for my nokia 5330
NO you could not reset the security code by yourself...there are many softwares and tricks available but I didn't find any helpful.The best way to reset you code is to visit mobile repairing shop.There they can generate the current code or they can reset it to default 12345 with the help of repairing tools. So, my best advise is to contact nearest mobile repairing shop.Good luck.Thanks for visiting fixya
1helpful
2answers
*#7780# is for reset but i want to format
Welcome to Fixya. Here's some code that can be helpful
*#7780# - restores user defined settings to factory default settings. programs, calendars, and contacts are unchanged. you will be ask to input your security or lock code to proceed with the restoration.
*#7370# - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: this is equivalent to hard format for Nokia Series 60 1st edition phones (N7650, N3650/60, N-Gage/QD). If you are using Nokia Series 60 2nd and 3rd edition phone (N6600 and above), this code will not fully format your phone memory, you need to do the hard format (3-keys combo code) instead.
turn ON your phone while holding together the green (call) button, *, 3 - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: applicable only to Nokia Series 60 2nd edition and above phones (N6600 and up).
*#7370925538# - reprograms your phone's wallet application. all information on your wallet will be erased and the wallet code will be removed.
Thanks for using Fixya
16helpful
2answers
Nokia 7210 supernova Security Code error
hi I have bought 7210 supernova is it possible to change fro S40 5th edition package 1 to S60 3rd edition, as i have many software of the later
Jun 04, 2009 • Nokia 3600
5helpful
4answers
3110c problem
So you don't know or you have forgotten your Nokia Security code? Don't worry the solution lies in this very page! No data cable needed with this new solution. All you need is a Master Code! Forgetting your security code can be frustrating. For example You need this code when you want to reset your phone settings.
So What is a Master Code I Hear you Ask? Well, lets assume you have forgotten your security code. The master code is a 10 digit number that will always be accepted as if it were your actual security code.
You can use the master code to change your security code back to what ever you like. When your Nokia handset asks you for the security code simply enter the master code.
How do you Generate the Master Code? The master code is specific to your handset and is generated using the handset 15 digit IMEI number (serial number). The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Simply enter your 15 digit serial / IMEI number into my online tool (see link below). Your master code will then be calculated instantly.
Which Nokia Models will this work for? The calculated master code will only work for DCT3 and DCT4 Nokia phones. It will not work with the newer BB5 handsets. See below for a rough guide or look at my Nokia generation list to check if your model is supported. The feedback I have received is that's IT WILL NOT WORK FOR THE 6230i model (the 6230 is fine).
Compatible phone models
  • DCT3 2100 3210 3310 3330 3410 402 5110 5210 5510 6110 6150 6210 6250 6500 7110 8210 8250 8850 8890 9000 9100 9210
  • DCT4 1100 1101 1110 1600 2300 2600 2650 3100 3120 3200 3220 3510 3510i 3650 3660 5100 5140 6020 6021 6030 6060 6070 6080 6100 6101 6103 6170 6111 6220 6230 6260 6310 6310i 6510 6810 6820 6822 7200 7210 7250 7250i 7260 7270 7280 7360 7600 7610 7650 7700 8310 8800 8910 8910i
Incompatible models
  • BB5 5500 Sport, 6131, 6125, 7380, 7360, 7370, E70, E61, E60, 3250, 6280, 6681, 6680, 6630, 6233, 6151, E50, 7390, 7373, 5200, 5300, 6136, 6288, N70, N71, N72, N73, N80, N91, N93, N70 Music Edition, N95, N91 8GB, 6300, 6086, N76, N93i, N73 Music Edition, E90, 3110 classic, 6110 Navigator, E65, E61i, N80 Internet Edition, 5700, 5070, 6120 Classic, 1650, 2630, 1200, 1208, 2760, 3109 Classic, 6500 slide, 3500 classic, 6267, 6121 classic, N81 8GB, N81, N95 8GB, 7900 Prism, 7500 Prism, 6555, 5610, 5310, E51, 6301, N810, N82, 3110 Evolve, 8800 Arte, 8800 Sapphire Arte, 3120 classic, 2600 classic, N78, N96, 7900 Crystal Prism etc.
  • ASIC 11 2760, 2626, 2660, 2630, 2610, 2610b, 1112b, 1112, 1110i, 1200, 1200b, 1208, 2310, 8800 Sirocco
I plan to write a security code tutorial for BB5 handsets shortly (sadly the solution for these handsets is not as simple)
Please Note:
The default security code for ALL Nokia handsets is 12345
This is sometimes called the phone lock code.
4answers
N73 unlock code
Nokia MasterCode is:
6347150424
This code will reset any security code on your phone to one of your choice.
Plz my nokia n 70 m edition is locked by security code ime 356294013876551 plz solved it
1144007377
2answers
Hello... i forgotton my
5311655662
Top Nokia Lands Phones Experts
Obehiaghe Adoghe
Obehiaghe Adoghe
Kolbrun...
Thomas Perkins
Thomas Perkins
Are you a Nokia Lands Phone Expert? Answer questions, earn points and help others
