U4 - 5328 xerox
Lamp ok, fuse of, termistor ok. is there a service code reset that needs to be cleared.
Dear,
You can reset the code thru diagnostic code 20-3.Hope it will help you.
Posted on Aug 16, 2008
6ya staff
SOURCE:
How to i fix the h2 code for sharp al 1540 cs
H2 is a termistor open....you have to reset it if it works ok if not you have to change the termistor..
enter service mode c - auto -c auto than enter 14 and start .....if the code goes it is ok if not change termistor.
Oct 31, 2014 | Office Equipment & Supplies
My xerox konica 7055 takes long time warm up,lamp not turn on
did u check your fixing unit, termistor termostat didi u clean and reset 47 or 35 mode
Feb 19, 2013 | Xerox Office Equipment & Supplies
Ricoh Aficio 2022 AllInOne Laser Printer error code sc 541
This error appears when you have problems with TERMISTORS in fusing unit. You have to replace termistors if you can't reset the service call condition in service mode.
pifonski
Feb 24, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Receive H 4 error code on zerox 1255 copier-nothing happens, the machine won't turn on-tried switching power of for 5 seconds nothing happened. Made sure the machine was pluged in a receptacle by its self,...
A H4 code is a problem with the fuser unit. That xerox is a Sharp copier. You may have a blown thermister or thermal fuse or a fusing lamp. You may need to repair the problem before you can clear it. I believe the code to reset it is in service mode SM 16
Mar 12, 2010 | Office Equipment & Supplies
ERROR SC541
push clear 1 0 7 and the clear/stop (one at a time in order) key this enters service modes, turn machine off/on (rocker switch) this will clear your code. this is a fusing code (low temp) so make sure no paper is in the fusing unit (hot, black and orange rollers)
Aug 10, 2009 | Ricoh Aficio 450 Copier
Sc 542 error code
press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
May 22, 2009 | Ricoh Aficio CL7200 Laser Printer
I Have Xerox 5821 Star Copier and it got U6 error. Help me out
U6 code means that you have a problem with the exposure lamp or exposure lamp circuit working properly.Hold down the 0(zero) key while turning the unit on and punch in the codes 20 start 3 this will enable you to clear the code unless you have a permanent problem where a part has to be replaced
Apr 21, 2009 | Xerox 5100 Copier
Service mode
call service --- possible bad thermistor (fuser)
could over heat
Mar 17, 2009 | Ricoh Aficio SP C410DN Laser Printer
RICOH AFICIO 650 WHAT DOES THIS ERROR CODE MEANS SC543-00
Try changing the termistor, must be damaged. and reset by total clear, 107 and press and hold the clear stop key more of 3 seconds.
Dec 03, 2008 | Ricoh Aficio SP C811DN-DL Printer
Xerox Copier problem
Turn power on and within 4 sec.press the following sequence;clear,exposure,clear,exposure.The screen will go blank.Enter '1' and '4' then hit print.turn off. This will reset H4 if the fuser has no problems such as a bad fuser lamp or thermal fuse.And yes it,s worth fixing with the right guy working on it!
Jun 30, 2008 | Xerox Office Equipment & Supplies
Open Questions:
197 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
