Computers & Internet Logo
Anonymous Posted on May 25, 2011
Hi I bought a new pci express x16EN 1210 Silence installed it in my pc worked fine was Then i moved the computer and tower and the monitor does not want to come on. Says power save mode and powers off. I unplugged the power for a few minutes like the store told me to do and still no monitor.The monitor is LG cannot remember the model and not home to check it. What can i do
  • 1 more comment
  • Anonymous May 25, 2011
    I should also mentioned it was moved to a different home from where it was setup but the monitor came on we shutdown unplugged it now nothing also new power supply
    Yes i did all that was on the computer all day
    was working great,Then whe n i took it home the monitor will not work.
    Same monitor was setup on.
    Is there anyway to boot from cd and reinstall the drivers
    The only thing we changed was the mouse.It was wireless now its plugged in.The computer worked fine until moving it and using a different mouse
    I set it up with a usb keyboard and when i moved it home i turned it on and worked.Realized i forgot to plug keyboard in onboard.Shutdown did that and no video display.
    Can the onboard keyboard have anything to do with it.Thats why i bought the pci express i unplugged my wireless keyboard cause it broke.Plugged my regular keyboard in turned pc on and no display..Thought my onboard display had gone.
    Should i get a usb keyboard
Anonymous
Level 2:
New Friend:
  • Expert 104 Answers
  • Posted on May 25, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
104
Questions
Helped
15406
Points
288
When you installed the software, the first thing you should see on the monitor is the change in the resolution,contrast,hue etc and it should ask you if you agree or not.
The software comes with a manual and the manual should tell you what PC (windows Xp, 7, vista etc) is compatible for it.
thanks,
George.
1helpful
Just trying to find out whether this computer will take a PCI sound card.
The this particular model of the computer has one spare PCI express slot , where an external audio card can be put in. Open the the system tower and look for an empty black slot on the motherboard.
You can purchase a PCI express sound card .
Regards
Proton
I start up my pc and get no signal to the monitor i have bought new leads for monitor cleaned out the pc.but i can only get a signal to the upper port on the tower please help i av bought a new graphics...
You will have to go into BiOS and change the graphics settings from on board graphics to PCI, AGP, or Pci-e depending on what kind of graphics card you have. It will be one of the 3 listed, if your computer is relatively new it's more than likely PCI-e, If it's fairly old it could be one of the other 2.
My integrated video card died so I bought a compatible new video card GeForce 7200 pci express. Monitor doesn't work with new card because the drivers for the old card haven't been uninstalled. I am going...
does your motherboard identify your new video card? make sure to put the new video card on the right slot. then check all the cables which is connected on your monitor going to the tower. make sure to connect the vga cable of the monitor to your new video card. try to power on computer and install the video card driver which comes with your new video card.
Graphic card ati 1650 pci express on boot up stopped working
Either your graphics card has gone bad or - the PCI Express slot on the motherboard has failed. Alternately you could put the card in another computer and see if it works. you could take it to a local pc shop and have it tested. I work for TechSupportPros of Spokane, WA - I would test the card for free.
Blank screen after turning computer on
Sounds like onboard video might have gone out. 2 suggestions, if the system is still underwarranty, send in for repair. If not, suggestion would be to open the case, and confirm type of slots AGP, PCI, PCI Express, and purchase a video card on the type to install.
Can't get Picture on Monitor, replaced video card
Boot up into the setup, usually F2- in the video section look to be able to make a change from Onboard to PCI ...apply-save change and exit ...also make sure you have connected the monitor to the correct area...I , like a big dummy, have often just hooked it up to the first blue socket i saw and of course...not much happens.
I hope this helps you Fred, (if it came with drivers install them)
please leave rating, thank you kindly
No video signal
The video card may have a jumper next to it or it need to be reset in bios If you know how at start up prees F1 or F2 or Del one of these will open Bios in the bios menu you will see setup instructions on the side or the bottom follow them and save if you are trying to add a video card it should say onboard or pci slect pci then press esc on your keyboard then press F10 to save settings then restart pc this should work but check the hp website for downloads get the manuel and find out about the video jumpers.
Monitor is blank when plugged into Nvidia Geforce 8600GT
is video card pluged in tell bios pci express video snaped down good
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
