Computers & Internet Logo
Posted on May 24, 2011
How do i get the zoom icon back on my taskbar?
3 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 18, 2009
SOURCE: lost dell remote access iconon taskbar
If you still have the shortcut for Dell Remote access in your start menu, right click on it and select copy, then right click on your taskbar and click "Open Folder" when the folder opens click paste.
Anonymous
  • 38 Answers
  • Posted on Apr 06, 2009
SOURCE: taskbar migration; missing battery icon
You can try the following:
Click Start Button,
Then select All programs,
then "accessories",
then, "system tools",
then, "system restore",
A utility will start. click Next.
(Please note that it will not cause any harm to your data so dont worry about it.)
after flipping through couple of screens, it will give you an option to roll back the settings to an earlier time.
Select an earlier Bold date (that means a system check point exists) click on a check point and click next.
It will ask you to restart after reload. Allow that.
(The system will be rolled back to the point you selected (select a checkpoint that was earlier than the problem occured)).
you will see that once the system will restart, it has restored the system settings to an earlier time and your problems are resolved.
Will appreciate if you can rate this solution offered to you.
Thanks & Best Regards,
Techno-Geek.
Anonymous
  • Posted on Aug 18, 2012
SOURCE: the zoom icon is missing from taskbar
To get back percentage on taskbar for text
Go to Menu on top and check Status!!!!!!!!
Disable pinch zoom and touchscreen
You should be able to do this in the touchpad settings, right click on the taskbar icon.
How to enlarge the icons on the toolbar
If you mean enlarging the task bar items please follow the following steps:
1-Access the Taskbar and Start Menu. This particular menu will allow you to customize your taskbar features and resize the icons. Click on the Start menu, or Windows logo, from within your taskbar.
2-Select "Control Panel," then select "Appearance and Personalization." On some Windows 7 computers, this option may also read as "Appearance."
3-Click on "Taskbar and Start Menu." This will open a Taskbar and Start Menu Properties dialog box on your screen.
4-Change the size of the taskbar icons. Place a checkmark next to "Use small icons" within the Taskbar Appearance section to make your taskbar icons appear smaller.
5-Click directly on the checkmark if one is already present to enlarge the size of your taskbar icons.
6-Save your taskbar icon customization settings. Your new taskbar settings will go into effect immediately. Click on the "Apply" button to save your changes, then click "OK" to exit from the Taskbar and Start Menu Properties menu.
On the bottom where the task bar (i think thats what its called) the bar with start and that on it i cant see it because my screen has zoomed ina nd i cant zoom out...How do i zoom out?
hey
I just figured this out! On the bottom right hand of the screen there is a an icon (near the battery meter) that says Dell Touch Pad. Open that screen and it lets you pick the scrolling and zoom settings. You can turn the zoom function off and it won't happen anymore
also if ur taskman hide automatically then u have selected the option of hide auto hide taskbar to iunselect u have to right clcik on taskbar then select properties then unslect auto hide taskbar it will get normal
still any probs in it inform me
I removed the pinned icon from the Taskbar by mistake and cannot get it back onto the Taskbar
You can also Right-click on the icon and select to pin to the taskbar or start menu
8helpful
Can I disable the pinch-zoom from the mouse pad?
Go to the touchpad icon on the taskbar and go to the pointing device properties . Go to the device settings tab, then click the settings button. On the left hand side there is a menu of items to select, click on pinch zoom and unclick the enable zoom box, press apply and ok. This should solve your problem.
Please let me know whether this works.
3helpful
The volume icon on my taskbar has been deleted from my computer how can I download it again
Missing icon from taskbar
1. If you have uninstall your Audio drivers from your system the volume icon will not show in the taskbar. You have to reinstall the audio drivers to restore the volume icon back to the taskbar
2. If the your volume icon is missing from the taskbar and you did not uninstall the audio drivers, then go to Start -> Control Panel -> Sounds,Speech, and Audio Devices -> Sounds and Audio Devices ->"Place volume icon in the taskbar" box -> Uncheck & check -> Apply & OK and your volume is restore at the taskbar. (Reboot if necessary)
Hope it helps.
7helpful
2answers
The zoom icon is missing from taskbar
8helpful
2answers
The zoom level on my new acer lap top keeps changing i have been in the control panel to try and stop it but to no avail its very annoying
Go to Control Panel > Mouse > Device Settings > Settings > Advanced Gestures > Pinch
(or alternatively right-click the Synaptics Pointing Device icon in your taskbar and select Pointing Device Properties)
Untick the box that says 'Enable Pinch'. This will disable the zooming.
I hope this helps, this is sooo annoying! I havent been able to do much on my acer at all because of the irratic zooming!
--Heidi.
M2000 battery and very slow
The Power Options icon wont move to the taskbar. Double click on this icon, this opens the Power Options Properties window. Go to Advanced then select and select and tick Always show icon on the taskbar then apply. This should put the icon in the taskbar.
Try freeing some space using disk cleanup. You can also go to Internet Options to delete files stored in history.
2helpful
Quickcam camera icon is missing?
Do you mean the desktop icon itself, or the taskbar icon?
If you just want the desktop icon back, navigate to "program files / logitech/ quickam" folder. Right click on the "quickcam" (it will have a pic of the eyeball camera). Click "create shortcut". Drag that shortcut icon to the desktop.
To make the the taskbar icon, make another shorcut, and drag it to the taskbar.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
