SOURCE: freelander td4 power loss at 70mph
yeah, don't drive so fast!!!!...seriously i would do what has to be done anyway to start. change fuel filter, air filter, spark plugs, spark plug wires. these have to be done at some point if they haven't been.. if that solves your problem, if not look at fuel pump, injectors.u didn't say if it used to go faster, maybe there is a limiter.
SOURCE: timing belt change
Go to your local parts store and purchase a book for your vehicle and have the advantage of the proper information at your disposal.Be wise to yourself.
SOURCE: i have a 52 plate freelander td4 and my timing
You don't really have a problem ! The TD4 engine uses a timing chain not a belt, thus no need to change it.
SOURCE: Low Fuel Pressure on Landrover Freelander TD4
causes .bad filter,gas line leak,tank leak call dealer to find aux pump.bad gas.i had a truck i replaced the in tank fuelpump 5 times one week they were all bad. could be as simple as your gas cap? any check engine lights on?
