SOURCE: Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
SOURCE: How do I retrieve messages on the Panasonic KX-T7030 phone?
By default, three options are enabled:
option #1: leave a message
options #5: call the operator
option #6: return to top menu
Here are some other features you may need
SOURCE: operations manual for Panasonic Phone System part # kx-tg5634
Problem has been solved. I was able to locate a Panasonic manual for our quad phone. Sorry to have troubled you.
Thank you.
SOURCE: Panasonic KX-TG2583. How do I change the time?
TIME/DATE ADJUSTMENT:
Press Function/Exit/Ch on the handset.
Press the up & down arrow keys until it points to 'program'
Press the Fwd/Edit > (yes key)
Press the up & down arrow keys until it points to 'tad program'
Press the Fwd/Edit > (yes key) the base unit will now display programming opitons.
Press '0'...'set time' is announced
Enter the time (hour & minute) using a 4-digit number
(Ex. To set 9:30 enter 0930)
Press * to select AM or PM
Press # repeatedly to set the day.
SELECTING THE NUMBER OF RINGS:
Press '2'...the current setting is displayed on the base unit
Press 0 or 2 or 7 to set the number of rings
(0='Toll Saver, 2=Two rings, 7=Seven rings)
Press Fwd/Edit (save key) a beep will sound
To return to normal mode press Function/Exit/Ch
I HOPE THIS HELPS! I copied it from my phone manual!
Best of luck!
Emma
SOURCE: How to get Panasonic kx-tg 1033 handset to enter lower case
RTFM
Testimonial: "This is where I should have started!"
