SOURCE: Motor stops running after a few minutes
I have this problem as well. Replacing the HEPA filter, the bag and the thin filter doesn't seem to help.
SOURCE: Miele Mistral S7280 won't run after changing the bag
The Mistral range is the same as the new S7 that's just hit Europe. Have you made sure that when you turn on the vac on the handle that you've switched the carpet mode on? There's a separate button just under the power on button that activates the Carpet setting. Other than that check the sole plate where the roller brush to check for a blockage.
SOURCE: Hello,
Permanent damage is extremely unlikely. It should work just fine when it has cooled off.
SOURCE: I have a miele S712 (2 yrs old worked fine
you have got dust in the micro switch and it is not latching on, if you look at this and clean it, that will solve your problem, however blowing the motir has probably wrecked the motor bearings.
