SOURCE: 2 uniden cordless phones aren't working
I don't know if this helps, but perhaps the problem is using two or more phones. On a whim, I charged a Uniden EXP 970 that my daughter gave me a few years ago. Charged right up and it has been working for about two days. I didn't think it would charge at all but to have it actually work, I was amazed!! Will post if it quits anytime soon.
FYI I bought two phones from AT&T, each around $200 and neither of them worked after a week. I was not happy! These less expensive phones seem to do a much better job!
Jann
SOURCE: remote retrieval of messages, uniden dect 6.0 cordless
30 seconds with a search engine got this page http://www.uniden.com/index/manuals_results.cfm?cat=59
Put in your model number and you're good to go.
Carl
SOURCE: uniden dect 6.0 display reads searching
Hi there, try this. Press and hold th eend key on one of the handsets, while holding the end key, press and hold the # key. After 3 or 4 seconds tha thandset should beep and read deregister Handset and underneath that "Base Unavailible". Select base aunavailible and confirm. Then tha thandset should read "Handset not registered, place handset on base" Once you place the handset in the bace cralde it should register in 5 - 10 seconds or so. then you should be good to go.
SOURCE: Will Uniden 2085 DECT phone work in india
Caller ID standards are different in India,so caller id won't display ; need to buy a converter which converts from DTMF to BellFSK standard
SOURCE: my cordless phone says
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
