Hi dear.. please help me.. i forgot my NOKIA E63 restore factory settings lock code. please send the how to reset my lock code to [email protected]
I have no factory settings code nokia 5230
A: How to hard reset lg rumor - Sprint phone LX260
There are several ways to hard reset Sprint LG Rumor:
1. Go into your security settings and do a standard reset.
Your password would be the last 4 of your phone number, unless changed already.
2. ##786# the select Reset. Password would be your MSL, which sprint has (call customer care for your MSL).
This is a factory reset, this will reset everything.
B: How to hard reset lg rumor 2 - Sprint phone LX265
To reset default settings:
1. Press > Settings > More... > Security and enter your lock code.
2. Select Delete/Reset > Reset All Settings. (A disclaimer appears.)
3. Read the disclaimer and press .
4. If you are certain that you would like to restore all the factory settings, select Yes.
Resetting Your Phone
Resetting the phone restores all the factory defaults, including the ringer types and display settings. All data
from Contacts, Messaging, Pictures, My Contents, Tools, and Settings will be lost, and preference settings will be
set to factory defaults.
2. Select Reset Phone. (You will see a disclaimer.)
4. If you are certain that you would like to restore all factory settings, select Yes.
or contact service provider
SOURCE: I need to reset a LG rumor touch to factory
If you have forgot the codes for your mobile you can unlock it by using the last four digits of your phone number or four zeros. If these codes are not working you can contact your network service provider to get the unlock codes.
If you need to reset your mobile then press the "Menu" button,from main menu scroll to "Settings/Tools" and select the option by pressing the center "Menu/OK" button.Scroll to "Settings" and select.Scroll and select "More". Scroll to "Security" and press your "Menu/OK" button.Enter in your phone's security code when prompted.
Select "Reset/Erase", then "Reset". A warning message will appear.
Press the "Menu/OK" button, then highlight and select "Yes" to confirm the reset.
Thank you !!
SOURCE: I forgot my lock code for my rumor touch, what can
I found a video that shows you how to fix this. http://www.youtube.com/watch?v=Ys6qi7n50eg
Hopefully this helps.
SOURCE: I locked my rumor touch
You can take it to your carriers store and they can access the phone and either tell you what the unlock code is or remove it for you. This is the only way as you must prove you are the owner of the phone.
