If you tried jailbreaking that might be the problem or you need to delete iTunes on your computer or try updateing iTunes try updateing first the if that docent work then delete it and reinstall it
This also happened to my iPod touch. You should try plugging your iPod to another computer, go to iTunes, and click on reset iPod. That's how mine worked. Hopefully this helps:)
1. Verify if your pc passes the system requirements.
(a) usb 2.0 port
(b) You are running the latest version of itunes
2. Recharge your iPod Touch
3. Check USB connections. Use a USB port that is built into the computer instead of using an external usb hub.
4. Restart iPod Touch. Do the following steps:
To restart iPod touch, first turn iPod touch off by
pressing and holding the Sleep/Wake button until a red slider appears.
Slide your finger across the slider and iPod touch will turn off after a
few moments.
Next, turn iPod touch on by pressing and holding the Sleep/Wake button until the Apple logo appears.
Is iPod touch not responding? To reset iPod touch, press and hold the
Sleep/Wake button and the Home button at the same time for at least 10
seconds, until the Apple logo appears.
5. Restart your computer then reconnect your iPod Touch
6. Try reinstalling iTunes. And if this doesn't resolve the issue, you can also try uninstalling iTunes then reinstalling the latest version.
7. Check if there are third-party software that might prevent iTunes from recognizing your iPod touch. Such software may be security software, anti-virus software and webcam drivers. What you can do is adjust the software settings or you may also temporarily disable the software.
If you find this helpful, kindly click the thumbs up button. Thanks! :)
SOURCE: My Computer and iTunes does not recognize my iPod
my Ipod keeps beeping when plug in computer snd won't do anything else
SOURCE: My computer doesnt recognize my ipod
This could be caused by a number of things, so here is the official Apple troubleshooter for this issue:
http://support.apple.com/kb/TS1369?viewlocale=en_US
Does your computer meet the minimum system requirements? Are the USB ports 2.0?
Try uninstalling, reinstalling all software
SOURCE: pc doesnt recognize iriver ipod
first of all iriver is not an ipod
try to download the driver named iriverplus that shuld work
put your ipod in disk mode by following these steps.
press and hold the Menu and Center buttons on the clickwheel. when you see the apple appear, switch your fingers to the center and play/pause buttons.
whena check mark appears plug it into you computer and it should detect and mount.
add music and have fun.
SOURCE: ipod is recognized in itunes but doesnt show up in "my computer"
It wont ever show up in my computer. Ipod touches are made not to show up.. sorry..
