Refrigerators Logo
Posted on May 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not cold in refrigerator - Refrigerators
Anonymous
Level 3:
Genius:
  • Master 1,044 Answers
  • Posted on May 23, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1044
Questions
0
Helped
184230
Points
3259
Please check the settings of Temperature control switch (Thermostat). It should be more than Half i.e. if numbered than more than 5. If the problem persists the I am afraid that colling gas has laked out. You have to get it charged again.
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
2answers
LG french door refrigerator with bottom freezer. Freezer is cold but the refrigerator is warm
Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...---/Refrigerator-freezer-is-cold-b...
Refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
LG Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...-/LG-Refrigerator-freezer-is-cold-...
LG refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
4 Reasons Why Your Freezer is Cold but Fridge is Warm ...
www.bestfridgereview.com/freezer-is-cold-but-fridge-is-warm
Jul 25, 2014 - Your freezer is cold but refrigerator is warm? This can be a very big problem. Check Out the top 4 most common problems and their solutions ...
Why is my refrigerator not cooling? - Refrigerator - iFixit
Refrigerator side is not cold
The refrigerator side of the unit is cooled by the cold air from the freezer entering the refrigerator side through passages in the wall separating the two. Be sure there isn't any food items blocking these passages. Also check the coldness setting in the fridge.
I’m happy to help further over the phone at https://www.6ya.com/expert/robert_24775b73ca70da93
Refrigerator is a Cold Spot Model #106.52534300 Refrigerator is plugged in and running, can feel cold air flowing from the bottom and the back of the refrigerator is cold. But the refrigerator and freezer...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
1helpful
THE REFRIGERATOR IS BUT FREEZER IS
the damper vent door that lets cold air from the freezer into the refrigerator isn't opening to let cold air flow,check to see if its iced up,or the cold control that operates it is working
After cleaning coils my refrigerator is still blowing warm air yet the freezer is cold what can I do myself to make the refrigerator cold?
There is a small fan which moves the cold air from the freezer to the refrigerator part. Make sure that this fan is working. If it is not turning, the cold air will not reach the refrigerator.
These fans are easily replaceable; however, you probably will have to remove the interior panels from the refrigerator to gain access.
5helpful
Refrigerator not getting cold
Refrigerators and Freezer combination units have one common compressor and coolant for both units. If the refrigerator section is not getting cold I would check the following.
The cold zone is not blocked by a bag or box? The cold zone would be the coldest part of the refrigerator which vents the cold air from the freezer to the refrigerator.
Is the fan working on the refrigerator to vent the cold air to the refrigerator? You should be able to hear it when you hold the door switch.
The thermostat is not working which I have found most common is the thermister is not registering the correct temperature causing the fan not to turn on.
1helpful
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
