Panasonic AG-DVC200 DV Digital Camcorder Logo
Anonymous Posted on May 23, 2011
Dead Pixel in Panasonic AG-DVC200 - Panasonic AG-DVC200 DV Digital Camcorder
Emmanuel Borja
Level 2:
Sergeant:
  • Expert 167 Answers
  • Posted on May 23, 2011
Emmanuel  Borja
Expert
Level 2:
Sergeant:
Answers
167
Questions
0
Helped
35117
Points
518
You can't do anything on dead pixel but still you can use the unit it will not affect any, else the dead pixel cover half of the screen.
How to fix a dead pixel
pressure method. 1. Start by turning off your monitor. 2. Find a pen that has a rounded, dull end and get a slightly damp cloth to protect your screen. 3. Fold your cloth in two so that you do not puncture it accidentally. You don???t want to scratch your precious screen, do you? 4. Put the cloth in front of the stuck pixel and start applying slight pressure on it with your pen. Do not put pressure anywhere else than on the defective pixel, or you may break additional ones. 5. Continue applying pressure, and turn your monitor on. 6. Remove the pen from the screen, and voil? ! The stuck pixel should be gone.
tip
Panasonic AG-DVC20 camcorder User Manual(PDF)
Hello
Sometimes it is very useful to have an soft coy of a user manual at hand to use when you do not know the exact steps to change a certain function, or enable anther.
Here is a great tip explaining where you will be able to find and download an updated PDF version of this manual. This site will also provide you with a huge database of other product user manuals. Click HERE to find out exactly how to download the manual. The above mentioned link will explain step by step how to download the user manual.
At this link you will also be able to read reviews on this product, compare prices, and get a general overview. There will also be a full spec sheet on this product. You will also be able to upload a user manual which this website does not have.
Click HERE to navigate to Retrevo, where you will be able to download the manual.
Also feel free to visit Panasonic's official website for news on their latest products. You will also be able to download updated firmware for your device. Click HERE to find out how to update your firmware.
I really hope this can be of help. Please rate accordingly.
Kind regards
Andrea
The Color is "Off"
Did you white balance both cameras in the same setting? Sounds like one was balanced in different lighting than the other; i.e., if you white balance a camera outside and then bring it inside, the colors will be "off" as you describe.
1helpful
Ag-dvc20p blue stripes in play back mode
Blue stripes in playback is an indication that you need to clean the heads. A Panasonic cleaning tape should work fine.
1helpful
DVC recorder
The physical tapes are the same size, but the encoding on the tapes are different. Unless the panasonic recorder can play DVcam, you're out of luck.
Dan
Color unbalanced, uneven across the frame
Things to try. I don't promise solutions. Check your Monitor. Reading the description lead me to think of a tube display rather than a chip. Otherwise order a head cleaning tape and give it a rotation.
Dead pixel or dust?
sir ,its not dead pixel .this is dust u contact any local repairer
Parts
p/n is VYQ1529. Panasonic lists this as discontinued.
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
