I have a Robo Kleen that I bought about a month ago, It's worked great up until this point and now I put it in the pool and it won't blow bubbles like it normally does ; it won't even move. How can I fix this? Is it fixable ?
Re: I have a Robo Kleen that I bought about a month ago,...
For troubleshooting assistance and a referal to a regional warranty service center (if needed) please contact Maytronics directly at www.maytronicsus.com or 1-888-DOLPHIN.
try keep working the wheels, it might free up. should be a easy fix. good luck and vote if'n I was of help.. jay the pool pump motor repair guy longwood florida
i had that problem, past year
open the motor check for rust stains on the round magnetic surface
i used a steel or copper brillo pad dry to sand down the surface
careful with those plastic motor screw washers to secure motor
If it is blowing fuses, it sounds like it is going to be your connection to the transformer and not the pool cleaner itself. Unfortunately, if you are not a trained electrician, you should not attempt to fix your transformer. It is very dangerous to try to adjust electrical settings without training, and I can't recommend that you do that.
It sounds like your gear box has gone out. If that is the case, the pool cleaners not going to work until you replace the gear box. Unfortunately, this is something that only a professional can do. Just to make sure that this is the problem, you should first check the wheels for any debris or damage. Then make sure that you don't have any clogs or jammed/cracked hoses.
Sounds like you have found the problem. Change the Black Pack. Not sure the pack is available as a seperate part. Suggest you contact Robo Kleen for that info. http://74.84.137.218/website/manuals/RK01A.pdf
Here is the users manual for these pool cleaners. You might be able to locate the information you are looking for there in the parts specification manual.
