AEG 24 in. Favorit 50730W Free-standing Dishwasher Logo
Posted on May 23, 2011
My Favorit 50730 the top and middle fault warning lamps flashing in the multi display indicating the 'anti flood system' has been triggered, can you provide a solution please. Thank you.
3 Related Answers
Anonymous
  • 76 Answers
  • Posted on Nov 27, 2007
SOURCE: Favorit 44070Vi 3 short warning tones
It is most likely to be the wash pump leaking underneath, the float switch lies underneath the dishwasher, if you tip it back slightly you will probably find that water will leak out, that will prove that it is leaking and it will probably work a couple of times after this but it isn't the answer i'm afraid, a wash pump is not really the sort of thing you should tackle yourself.
BIKER T
Terence Fourie
  • 909 Answers
  • Posted on Sep 21, 2009
SOURCE: favorit 35085Vi - possible cause of anti flood
It can only be due to a leak running into the base. Suggest you remove RHSide cover and run washer.again. Inspect while running and see where leak is comming from. My guess, its the main motor.
Anonymous
  • Posted on Jun 08, 2010
SOURCE: aeg favorit 64070vi, i 30 fault, think that the
Thanks to all.
What we couldn't work out is what is actual mechanism of anti-flood triggering, and how therefore to reset it - and why all these other fixes work - but then it occurred to us, that problem is when water gets into the base and can't get out.
Our problem was that water inlet at top of washer came loose so water ran down outside the drum but inside the dishwasher, into the base. We tried the tipping method but this just moved water around and I think there must be sensor there which, if it stays wet, leaves anti-flood triggered.
This makes sense because other high level overflows from drum discharge into base - so if it was to overflow, it goes into sealed base only, wets the sensor and triggers anti-flood.
Our solution was patience - tipped it fully on its side, pointed a hot air blower into it for hour or so, then left it overnight. Tipped it back next morning, water which had run into side panel ran out, so it was upright with its base dry - and (touch wood) it worked like a charm.
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
1helpful
2answers
I work for a garage and we have a 1998 mystique that wont start we were wondering if there was some sort of anti-theft systeme that we dont know about and also we would like to have the were abouts of the...
Starting System
The function of the starting system is to crank the engine at a speed fast enough to allow the engine to start. Heavy cables, connectors and switches are used in the system because of the large currents required.
The starting system consists of a gear reduced starter motor, battery, remote control switch (ignition switch) and relay.
Vehicles equipped with automatic transaxle have a transmission range sensor attached to the circuit which prevents operation of the starter motor unless NEUTRAL or PARK are selected.
Vehicles equipped with a manual transaxle have a start inhibit switch in the starter control circuit, which prevents operation of the starter motor unless the clutch pedal is in the applied position.
The anti - theft protection system provides protection from unauthorized entry into the passenger compartment.
The system is controlled by an anti - theft alarm control. When armed, unauthorized entry into the vehicle is detected by lamp switches.
Once triggered, the system flashes the headlamps, the parking lamps, the alarm indicator, and sounds the horn. In addition, the starter circuit is disabled to prevent starting the vehicle until the system is disarmed.
System Arming
The system will be armed by the remote entry transmitter when the following input sequence is followed:
  1. Turn the ignition switch off and remove the key.
  1. Close all doors (unlocked).
  1. Press the LOCK button on a transmitter to lock doors. Alarm warning lamp will turn on.
  1. Wait for the anti - theft warning lamp to turn off.
The system will also be armed when the following input sequence is followed:
  1. Open a door. Alarm warning lamp will flash.
  1. Lock doors with power door switches. Alarm warning lamp will now glow steadily.
  1. Close all doors.
Opening any door will activate the alarm after the alarm is armed.
Disarming an Untriggered System
The system can be disarmed by performing one of the following procedures.
  • Driver or RH front door is unlocked with a key.
  • Driver door is unlocked by pressing the UNLOCK button of a remote entry transmitter.
  • If remaining in the vehicle, turn the ignition switch to ON or ACC position.
System Triggering
The armed alarm system will be triggered if any door is opened without using a key or a remote entry transmitter to unlock the door first.
Disarming a Triggered System
Carry out either of the following steps will disarm the triggered alarm system.
Two minutes and 45 seconds after the system has been triggered, the horns and exterior lamps will shut off automatically. The system will then reset to an armed state and will trigger again if another intrusion occurs.
Passive Anti-Theft System (PATS)
The Passive Anti-Theft System (PATS), known as SecuriLock, is fully passive in operation and requires no special procedures by the driver to arm or disarm the system. It is invisible to normal scrutiny and is operated by a transponder within the key body. This communicates with the module through a transceiver mounted around the ignition switch lock barrel.
The PATS functionality is incorporated within the powertrain control module.
PATS keys contain an electronic device inside, and are physically larger than a non-PATS key.
The transponder code reading is carried out when the key is inserted into the ignition lock barrel, and turned from position 0' to position II' or III' to crank the engine. If the PCM receives the correct code signal, the engine will start. Should the code received not be recognized, the engine will not crank as the PATS is still armed and the engine immobilized.
Anti-Theft Indicator
Whenever the ignition is switched on the anti-theft indicator will remain on for three seconds while the system carries out an initial ignition key-read.
The anti-theft indicator will flash rapidly for three seconds to indicate the PATS has immobilized the vehicle.
For additional information on the PATS fault codes, refer to the Diagnosis and Testing section.
Aeg favorit 64070vi, i 30 fault, think that the anti flood switch is triggered
Thanks to all.
2helpful
2answers
Anti flood system triggered Favorit 40660 dishwasher
The problem was solved by opening the machine and finding that the bottom "Y" pipe that has 3 inputs is of extremely poor quality and perforates with pin holes allowing a small amount of water to squirt out. This triggers the anti flood and error status lights flash. The outlet pump is activated and machine does not do anything. You need to replace this hose or like I modified it to work from a 32mm Y plastic junction available from most hardware shops. The wire clamps for this was replaced by "jubilee" screw tight clamps.
I worked on a table and also removed the "Brick" placed at the bottom for balance purposes by cutting the back plastic down with a saw. This made the job very easy...
Warning lights flashing for Anti flood system triggered and dishwasher not operational
The bottom "Y" 3 point hose at the bottom connected to main motor is of poor quality and does have 3 wire clamps. The hose does perforate and small pin hole causes water at the bottom to trigger the anti flood system with warning lights flashing and pump motor on ...
1helpful
Aeg favorit senorlogic three beeps and no evidence of problem but dishwasher won't work
Anti flood system triggered that puts the machiene in pump out mode. This machiene has a poor quality "Y" pipe at the bottom that is prone to pin holes in the pipe due to poor quality and extremely thin. The pin holes cause a small amount of water to activate the Anti flood micro switch on the polystireen float at the bottom of the washer.
Antiflood system triggered-how to reset on aeg favorit 35080vi
Hello everyone. Have just fixed a problem with my aeg dishwasher thanks to this site. My anti flood switch in, so I unpluged, pulled the machine out, tilted it, wiggled the outlet hose, which I think was a little kinked and way hay it works. Thanks FIX YA. Good luck everyone. Carolyn
AEG 40630 -top and middle lghit are flashing
This is caused by the Anti-Flood device at the base of the machiene being activated. This device detects water leaks and is a polystireene float / micro switch that puts the machiene in pump out mode only. You need to determine where the leak comes from (pipe or perforated hose pin hole or pipe clamp etc.) If you tilt the washer and some water comes out from the bottom it is a clear indication that there is a small leak.
4helpful
2answers
AEG Favorit 50730 Dishwasher
The dishwasers have heat (inductive) elements in line with the top sprayer hose and is about +/- 15 cm long and has an electrical push on clip at the side of the device.
Top AEG Dishwashers Experts
Paul Carew
Dominic Harborne
Level 1 Expert
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
