SOURCE: kenmore gas dryer not heating
GAS DRYER, NO HEAT. CHECK THE HEAT SETTING FIRST.
IS IT ON AIR FLUFF? I'M NOT BEING SMART, BUT YOU WOULD BE SURPRISED HOW MANY CALLS I TAKE THAT ARE ON AIR FLUFF. SECOND, LISTEN FOR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER. IF YOU HEAR IT, LOOK IN THE INSPECTION HOLE ON THE FRONT OF THE DRYER, OR REMOVE THE TOE PLATE TO VIEW THE IGNITOR. IF THE IGNITOR GLOWS AND THEN CLICKS OFF BUT NO FLAME, YOU HAVE A BAD SOLENOID ON THE GAS VALVE. IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF, THE RADIANT SENSOR ATTACHED TO THE SIDE OF THE BURNER ASSEMBLY IS BAD.
IF YOU DON'T HEAR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER, THE MOST LIKELY CAUSE IS THE THERMAL FUSE LOCATED ON THE BACK OF THE DRYER DOWN NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM ATTACHED TO THE EXHAUST DUCT WITH TWO WIRES ATTACHED.
SOURCE: dash vents not working
I hate to question your intelligence, but are the vents open with the knob below them?
SOURCE: Condensation
Turns out the vent was obstructed. Re-positioned the custom-fit door and problem solved.
SOURCE: Wet dishes; steam does not escape
Hi, Most dishwashers do not have steam vents! there are several reasons for poor drying in a d/washer! The first one is to see that you have rinse aid in the machine as this aids drying! Next if you have rinse aid then is it being put into the machine when it needs it? Also you must bear in mind that the dishwasher need to heat on the last rinse to create the heat to dry the items which use the steam to dry them. Check the rinse aid first and see how you get on....
Let me know.......
SOURCE: PROBLEM WHEN SELECTING THE DIRECTION FOR THE AIR
Sounds like you have a supply vacuum problem. When you lose supply vacuum to the control head it defaults to defrost.
