Canon PIXMA iP4200 InkJet Photo Printer Logo
Belinda du Preez Posted on May 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi there my printer Canon pixma ip4200 keeps on flasing the on button and orange light. it does not print and the bottom light also stays on. what is the problem
Anonymous
Level 2:
  • Expert 113 Answers
  • Posted on May 23, 2011
Anonymous
Expert
Level 2:
Answers
113
Questions
Helped
66707
Points
309
Any error code displayed on PC ?
Canon Pixma MP160 doesn't print
Try doing a Reset.
Reset Printer Canon PIXMA MX310 or Canon MP160
  1. Leave the cartridges in the device.
  2. Turn off the printer using the on/off button.
  3. Keep the reset button pressed and press the on/off button now also. ...
  4. Release now the on/off button. ...
  5. Now open the printer and press the On / Off button. ...
  6. Now the printer with the on/off switch off button and turn on again.
More items...
Feb. 28, 2017
Reset Printer Canon PIXMA MX310 or Canon MP160 - Printer ...
10helpful
2answers
My canon pixma ip4200 flashes orane 5 times
How to reset waste ink / blinking printer canon ip4200
With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
While holding the Power button, release the resume/Cancel button. (DO NOT release the Power
button.)
While holding the Power button, press the Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
When the Power LED lights in green, press the Resume/Cancel button the specified number of
time(s) setting).
After pressing the Resume/Cancel button the required number of times -you must press the On/Off button to perform the task. For Example Pressing Resume/Cancel 1 time, then press On/Off - does a Service Test Print
Time(s) LED indication Function Remarks 0 times Green (Power) Power off When the print head is not installed, the carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings After entering the destination settings mode, press the Resume/Cancel button the specified number of time(s) to select the destination. For detail, see "Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used in servicing.
15 times Orange (Alarm) Return to the menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2helpful
How can I reset the waste ink counter in the printer Canon Pixma IP4200 ?
you can reset it following this procedure:
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold POWER button. Do not release the buttons. The LED light should be green to indicate that a function is selectable
  2. While holding the Power button, release the Resume/Cancel button, do not release the Power button
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  4. When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  5. Press the Power button. The LED lights in green, and the reset is performed. When the operation completes, the printer returns to the menu selection mode automatically
  6. Press the power button to exit service mode.
Then you should do this http://erkinson.altervista.org/blog/2010/canon-ip4000-disassembling/
2helpful
2answers
Paper will not fee, printer will not print
two cartridge inks at end continually flashing so is this why the paper wont feed?
1helpful
How do i fix "Waste ink full" to resume printing
Hello there
Canon Pixma iP4200, Reset Procedure
  1. Turn off the Printers.
  2. Hold Resume button click POWER.
  3. Hold button RESUME, release POWER
  4. Then press the button again twice RESUME.
  5. Release all the buttons.
  6. Indicator led in green and stay green.
  7. Click the button 4 times RESUME, if you want to make another transaction. :
Look at the table below:
· 1 led- Orange – Service test print 1 times – Orange – Service test print
· 2 led – Green – EEPROM information print 2 times – Green – EEPROM information print
· 3 led – Orange – EEPROM initialization 3 times – Orange – EEPROM initialization
· 4 led – Green – Waste ink counter setting 4 time – Green – Waste ink counter setting
· 5 led – Orange – Destination setting (Press Power > Press Resume 3x) 5 times – Orange – Destination setting (Press Power> Press Resume 3x)
· 6 led – Green – Print head deep cleaning 6 times – Green – Print head deep cleaning
· 11-13 led – Orange, Green, Orange – Return to menu selection
· 14 led – Green – Left margin correction 14 times – Green – Left margin correction
  1. Turn off the printer POWER button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
1helpful
ORANGE LIGHT BLINKS TWICE
2 blinking means "No Paper"or "No Paper in tray"
4helpful
Waste absorber is full in canon iP4200?
Follow this instruction:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
4) When the Power LED lights in green, press the Resume/Cancel button 4 of times.
5) Then press the Power button, then press it one more for turning off printer.Restart the printer and it will printing again.
2answers
Error code 6A00
6A00 error on a Canon IP4200 is an AP Postion Error. This means one of three things. A problem with the sheet feeder, Logic board or the Purge Unit. Sadly these part are either working or not working and are difficult to repair. You could try resetting the EEPROM on the unit by entering service mode. A service manual will show you how to do that:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
If that helps please rate my solution
Will not print
press and hold the 2 top buttons on the printer for about 5 seconds - this should reset the printer
old marine
old marine
ZJ Limited
ZJ Limited
