Question about Cell Phones
Motorola karma cell phone has water damage. the buttons work but screen display doesn't. when i turn on the phone, the screen flickers then goes black.
  • 139 Answers
Hi, when ever a phone drops inside the water, first remove the battery cause the battery life might be damaged,and also in that process the phone is still working because the battery is still inside the phone.
You will need to service the phone for the phone to be free from water,cause if the water dries inside the phone it will damage an IC or a chip inside the phone and it might cause more damage to the phone.
After, disassembling the phone is the next step.
Get a phone screw and unscrew the phone from the back by removing the battery and you will see some screws, unscrew possible screws and open the phone.
Get a "methylated spirit"( check Google image) and a small brush, remove the board of the phone and deep the brush inside the methylated spirit,brush gently on the board of the phone. After brushing, get a dryer to dry up the board of the phone and live it for a while to dry.
After some minutes,assemble the phone back and fix in the battery. Make sure during the process you are charging the battery of the phone.
I guess that's all you need.
After doing these process, And still no luck, you will need to replace the flex of the phone.
Flex problem
The flex of the phone is located inside the phone, it controls the functions of the screen of the phone and it's controls the display of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
Hope it helps.
Thanks for using fixya...
Posted on May 23, 2011
SOURCE:
How to use motorola unlock code
You can use Unlocking instructions to enter the unlock code in Motorola KARMA QA1....Visit the site
Simpleunlocking.com/motorola-karma-qa1/rs16wp9/ get Unlock code and instructions ,unlock it step by step..Unlocking instructions is below:
Motorola Karma QA1 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Motorola Karma QA1 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola Karma QA1 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola Karma QA1 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola Karma QA1 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola Karma QA1 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Sep 13, 2012 | Motorola Mobility Karma QA1 Cell Phone
MOTOROLA KARMA SUBSIDY CODE
simply call 1-800-331-0500. Tell AT&T that a friend gave you this phone because your Net10 phone (or what ever sim phone is popular in your area) isn't working and you would like to be able to use your SIM card in this phone. If the phone model is allowed to be unlocked they will give you the code with a smile you can hear over the phone.
Sep 08, 2012 | Motorola Mobility Karma QA1 Cell Phone
My phone wont turn on
Try a battery pull.
If that doesn't work, try a Hard Reset.
Hard Reset
1. Power off phone
2. Use hardware keyboard
3. Press and hold the 'X' key and Power button until you see a screen with an exclamation point inside a triangle
4. Press and hold the Volume Up key then press the Camera button (I had to do this twice) to get menu screen (Linux back-end becomes VERY apparent here)
5. Using the D-pad, select one of the Wipe options (specifically Wipe Data/Factory Reset)
6. Confirm your selection and wait for it to complete
7. Reboot the device
if the problem still persists, your phone might have water damage and may need replacing.
May 30, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Motorola karma. Only the red key works, none of the others is recognized. Took battery out, no help
Hi, most problem caused by keypad not functioning, is always water issues.
Unscrew the phone and clean up the keypad area. And your done.
After cleaning up the keypad,if it does not work, means that the problem is from the board of the phone.
There is an IC inside the phone that controls keypad function, when IC gets damaged, keypads will not function until it's replace.You will need to contact a skillfully personnel for help.
Thanks.
Oct 09, 2010 | Motorola Mobility Karma QA1 Cell Phone
I have a motorola karma the back button wont work if my cell is open but it works when its closed also the down button doesnt work.and now the a button doesnt work either ? ive only had it for about 3...
So the phone I have is the motorola hint, QA30, actually identical in design (except square, red and black) and I have similar problems, my right navigator (right shoulder) and my up and left buttons, as well as my send button, will randomly stop working, I find (in all seriousness, no joke) that sometimes hitting the phone (lightly of course) seems to get the buttons to work again,
Jun 17, 2010 | Motorola Mobility Karma QA1 Cell Phone
My unlock button on my keypad wont unlock
Since the Karma is a relatively new device it should be covered under warranty. AT&T Warranty # 1-800-801-1101. If for whatever reason it is not covered (has liquid damage or physical damage) we offer repair solutions for malfunctioning cell phones. A repair for that problem typically cost between $20-$60.
Spring Mobile Service and Repair 720-274-2492
Jan 19, 2010 | Motorola Mobility Karma QA1 Cell Phone
I CANNOT CALL OR EMAIL BECAUSE MY KARMA SCREEN IS BLANK
We have fixed several Karmas with this problem. Please contact me if you still need your Motorola Karma fixed. Thank you.
-Jim Groves, Owner
BongoPc.com Computer and Cell Phone Repair
863-206-7560
Jan 01, 2010 | Motorola Mobility Karma QA1 Cell Phone
Cell Phones Logo
235 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
