No, the Epson Stylus C43SX design requires that both cartridges are present and working i.e. not empty. If you wish to always print from one cartridge e.g. black, you can refill the empty color cartridge with distilled water and reset it to full. For this you will need a chip resetter (very cheap - see e-bay for example). Do not run with a dry reset cartridge - you'll end up with a damaged print head.
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with black ink missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with black ink missing even if you aren't using it. That's the case with your Canon printer.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
To print with black ink only, you have to go Print, on the window that shows up click on Preferences then select the Color tab and tick the check-box for Print in Greyscale.
But bear in mind that ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you print with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution
As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue.
The Ink Cartridges Empty options are described in the table below:
Ink colors outOptionPrint mode possible
All
Cancel
None
Black
AND
Cyan, Magenta, or Yellow (any or all)
Black only
Continue with other colors
Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available
Light Cyan or Light Magenta (either or both)
(Black still available)
Print with black ink only
Grayscale
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print
settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the
empty color cartridge because they are programmed to clean ALL the ink
nozzles. The only way to continue printing is to replace the empty ink
cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
If your print driver is set to color. It will use all the colors to make black.
Because the machine is ink jet it needs to clean the print head to stop it from drying out. It will use color ink to flush the print head every two days.
When ever in receives a fax it will use some color when printing a fax, particularly Cyan.
If you only wish to print or receive faxes in black there is now a version of Brother fax that only uses black ink and has no color inks. However it may not be available in your region. If you try and cheat the system you will only kill your print head.
