SOURCE: Arctic Air fridge stops each night and needs to be reset
please check your input voltage at night it must be between 210v - 240v if it is all right than please change your timer which was located in your back of your refrigerator. i'm sure that it your problem will be solved.........
SOURCE: Refrigerator will not go on.
I will need your model number to help you better. Below is a photo of where you may find the number. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
SOURCE: Hi, we have an Arctic Air frig R22CWF3 One or
Yes its a timer and/or a Klixon switch that mounts to the Evap coil. It sounds like the timer is working, because it will come back on after a time out. I would look for the klixon to be bad. Small switch with two wires that mount to the evap coil pipes with a clip. This (makes) to tell the timer its ok to defrost, then at a certain temp say 55 degs it will break to stop defrost. The timer is staying in to a default time of aprox 45 mins.
