Question about Maytag MAV7657EW Top Load Washer
What year is my matag washer model number MAV7657EWW?
  • Anonymous Mar 14, 2014
    computer module for matag washer model number ha5500bwq
  • 3,018 Answers
Regards, Tony
Posted on May 22, 2011
6ya staff
SOURCE:
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Turntable not working & keys "stick"
8 years old, huh? In my experience, once faulty, may keep on doing so even after fix. So if it were me & I could afford it, I would get a new one with a warranty.
Feb 26, 2010 | Microwave Ovens
MATAG NEPTUNE WAHER LEAKS FROM FRONT DOOR
hi there,
base on your problem, and other like what you say they changed the seal gasket of the door to avoid the water from spilling or leaking on the front door.
Hope this initial info helps.
Jun 04, 2009 | Maytag Neptune MAH7500A Front Load Washer
Matag washer may be leaking, esp when in use.
Remove the front panel from the washer. Fill the tub with water and then set it for spin.
Look for water coming from the machine. If so, report back as to where the water is coming from.
If no water is coming from the machine......
While the water is pumping out, look at the drain line in the wall and see if it backs up.
If so, call a plumber to clean your drain lines.
Mar 04, 2009 | Maytag Washing Machines
No hot water to wash
Check the particle filter screen in the hot water hose. It is located in either end of the hose, or sometimes just inside the inlet on the solenoid.
In my experience this has been the culprit over 60% of the time.
Dec 17, 2008 | Maytag PAV2300 Top Load Washer
1985 Matag Washer
Hi Tim,
I was working on a 1989 kenmore washer today and had a similiar issue. It is gross to find what causes this or maybe a long cycle w/o enough soap to hold the dirt causes the problem. The first issue was a 20 year accumulation of soap, dirt and oil plus the years turn it black on top and very oily.After one use everyone hates washer magic for not instantly curing the years of build up. It is not your fault, you don't see it and no one has told you,.. till now. This stuff will reside in the back bottom of your maytag and be 2 inches thick, ohh yeh. A good cleaner will take strategy and months of preventive work to reverse the build up. Like your veins good meds will take a while to work or if youre me I would pull the boot spring, front panel and remove the front of the tub and hose it out.
Post a not if I am wrong or give more info an I am glad to help.
Aug 24, 2008 | Maytag Neptune FAV6800AW Top Load Washer
High speed spin problem
contact maytag at 1-800-688-9900 and ask whats going on and you need your machine fixed while it is under warranty, it is only covered for a year.
they may refer you to a whirlpool number but whirlpool now ownes matag so this is ok
Jan 21, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag MAV7657EW Top Load Washer Logo
387 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
