Rusting of the door on a stainless steel refrigerator
True stainless steel will not rust, but it can get rust stained, which could be removed. Without any further info about your situation, I'd have to guess that you have a high iron content in your water supply, and thus rust issues with your sinks, etc., unless you have a good iron reducing softener and the water to the refrig is not running through that softener. Again, without further info, I'm guessing the rust issue is at or below the water dispenser area. Keeping the water from spilling over the drip tray will help. You might try Wink rust remover, but do test it on an inconspicuous area first to make sure it will not adversely affect the finish in a visible area.
