I bought the replacement can and can't get it to spray in device. Batteries are good because yellow light is on. It sprays when not in device so I know the can works but when I insert it and click it into place, it won't let me do the 'blast' spray and also does not work on sensor
I tried a few things and I'm not sure which was the trick or if it was a bit of all. I detached the sprayer hose from the container and put the hose and sprayer end in a bucket of water in case old spray was in the nozzle then tried spraying it in and out of the bucket for a while trying to dissolve any plugs. Still didn't work. Then I put the container up higher than the hose and sprayer and tilted container and tried spraying for about 15- 25 seconds and it started spraying again. Good luck!
No fuel ! Spray carburetor cleaner into the engine through the throttle body . SECURITY light lit ? Injectors firing ? Just replacing parts isn't the way , you have to test . If there is spark , yellow or not it's fuel related . Or engine crank , cam timing off . Some good videos on youtube .
Either your gun is dirty and the valve spring can't close the tip valve properly or the seat it pushes against is damaged. First try cleaning the gun very throughly. Take it apart and get everything out of the gun that doesn't belong there. If it still does the same thing you can buy a repair kits for the paint guns but they're usually expensive and you're almost always better off replacing the gun.
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
You don't want to be spraying those locks with anything, unless it's an electronic-approved spray. They are electronic and can short VERY EASILY. My advice would be to have the lock replaced.
Remove the cover and check is a spider has built a web over the tilt bucket. I have to clear mine ona regular basis. If this is a proglem, spray the inside if the cover with a surfase spray.
I bought DANCO "universal faucet pull-out spray hose - fits all facuet brands" from Lowe's, which came with all kind of adapter and the hose quality seems to be better than overpriced Grohe spray hose replacement (Grohe part # 46092). The only problem is that you may have to prepare a large rubber washer in order to the handspray (Grohe part#46298) as I don't see this large washer in the package but it is very important to fit in place to prevent water leakage. - Michael
This is a common issue with spray types of perfume and cologne. It is very easy for the head to break.
The best thing you can do is to try and find another spray bottle of some sort and use its spraying device in place of the existing one. If that isn't an option, you could always exchange it for a new one if it is mostly unused. Most retail stores will replace it, just tell them it came like that.
If all else fails you always have the option of permanently removing the spraying device, turning your bottle into a pour style of perfume bottle. Then just wrap some plastic over the top to keep it sealed.
put them in hot water and shake them for a good 2 minute and then spray with can upside down for a few seconds. This sometime cleans the spray tube. Make sure tip is clean.. try again..If still not working then dispose safely according to local laws.
