Navman iCN 330 GPS Receiver Logo
Posted on Aug 15, 2008
How to change battery
Navman icn 330
  • jkeny Nov 30, 2008
    I have the same problem on a Navman S30.
    I know replacement batteries can be bought on eBay for these GPS units but how is the battery replaced - I can't find any instrustions on-line for opening the unit.
    Any help?
  • Anonymous Jan 22, 2009
    Re ICN 330 - I have same problem.How does one replace the internal battery?
    Who ever asked about the unit only working in the car most likely also has a U/S internal battery. Also believe the pin connector on the 12 v car charger, GPS unit end , is suspect in connection .
    Ricmac
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
234
Points
Better late than never, but jkeny you can easily replace the battery. Ive done iton mine, but unfortunately it turns out that my charging circuit has failed and it might as well not have a battery any more.
I don't have my 330 in front of me but from memory you need a small (3mm ish) phillips head screwdriver and about the same sized flat head screwdriver.
Undo any external screws (i cant recall but i think theres one or two on the back) Use the flat head screwdriver in the small recess on the side of the facia that looks like it's designed for a screwdriver to fit in the slot and twist it to start removing the face plate off the gps. Then use the flat screwdriver to gently work it off top and bottom towards the other side (be careful to do the far side last as that has some retaining clips that you can break that hold the whole face together).
Once the faceplate is off, undo the 4-5 Phillips head screws holding the gps screen to the body and the battery is under the green securing lugs, which you have to use the Phillips head to remove.
Then you just unplug the battery and then wiggle it out.
Fitting the new battery is a reverse of this process.
  • Anonymous Dec 26, 2010
    I checked my GPS and i had it slightly wrong. The faceplate comes off after lifting on the right hand side, then you need to use a small security bit screwdriver (About a T6 it looks like, one was included with my replacement battery ki) to split the GPS face off, then you need to use the same security driver and take the security screws off the green mounting for the battery, unplug it and remove it.
Anonymous
Level 1:
  • Posted on Aug 16, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
234
Points
Dear sir
i have a navman, icn 330. when i brought it i could set it from home, but it doesnt happen now. it only works when charging in the car and works only in the car now. What is the reason for this?
I have a very limited postcode selection. We find it increasingly difficult to use the icn 330 due to the restriction on postcode characters how can we update it.
http://navman.com/in-car/europe/uk/Customer-Support/Software-Updates/
go there, please note you will need to insert the original cd that came with the navman to update it
5helpful
2answers
How to change battery Navman icn 330
hi location inbrisbane to buy new battery for 330icn navman thanks
1helpful
How do you clear recent trips on navman icn 330
http://www.navman.com/ look up the help menu
4helpful
2answers
Misssing SD Card for NavMan iCN 330
I have a 310 and purchased an SD card for France from Navman, it says it works in the 310/320/330 so my guess is that a 320 map will work in a 330.
2answers
Map upgrade
I would like to order new maps for mine GPRS-ICN 330. I am interested bought new maps from the countries like:Holland,Spain, France, Germany, Belgian. I need to upgrade mine GPRS navigation (new maps).
And tell me it's possible to have them in Polish language?
Tell me where I can bought them because when I looking in yours web site I can't find the products what I need.
Thank you for your help in advance.
Is mine contact email:[email protected]
Top Navman GPS Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Mike Cairns
Mike Cairns
Are you a Navman GPS Expert? Answer questions, earn points and help others
