Optics Logo
Posted on May 21, 2011
The rubber casing has gone sticky - Praktica Optics
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 19, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2139
Points
Many cameras and binoculars are covered with a sprayed on thin layer of rubber which breaks down after about 5 to ten years. It becomes very sticky and can be scratched off with a fingernail. This leaves a messy surface which can be cleaned off with methylated spirits. Other solvents will work like isopropyl alcahol but avoid using solvents like cellulose thinners or white spirit as this can attack the underlying plastic on some cameras.
1 Related Answer
Anonymous
  • 226 Answers
  • Posted on Nov 24, 2011
SOURCE: rubber housing on Sigma binoculars has gone sticky
  • Moisten a soft cloth with ammonia or Windex. Rub it over the sticky area to remove some of the damaged surface.
  • Ammonia can be used as well, but should be used with caution as it can cause damage to some plastic surfaces.
  • If the sticky, damaged surface remains, it can be scraped away with a spoon or dull knife.
  • Please note that these fixes are only temporary. Once the plastic starts to degrade, it will continue and the problem will be recurring. It is best to replace these parts whenever possible.
  • Ad
    Navman icn320, very sticky rubber case how to clean?
    To remove the stickiness from you Snooper sat nav use a white none scratch saucepan scourer and Cillit Bang black mould remover. Use only the mould remover do not use any water. Use just enough mould remover o moisten the scourer to avoid getting liquid into electronics. It takes a bit of work to clean the corners and nooks and crannies. Protect the screen from damage while cleaning, the remover itself will not cause any damage to the screen. Don't put too much pressure on and the sticky mess will come off.
    Oster wine opener sticky rubber surface
    Did anyone have an answer to this? I have had the same problem. I like the opener, but the parts of the rubber surface that are not usually handled get quite sticky. Any thoughts on preventing this, or if not on removing the stickiness?
    3helpful
    3answers
    Sticky rubber drill handle
    I would try wiping it down with some Goo Gone and see if that helps.
    Aug 21, 2012 • Drills
    2helpful
    What is the finish on the black matt speakers
    Unscrew the front of the speaker, hold the casing over a baking tray, repeatedly wash and work the thinners into the casing with a clean paint brush.This will gradually remove the sticky coating leaving the surface smooth and clean. Don't forget to wear rubber gloves.
    2helpful
    2answers
    Brother CS80 ..... bobbin winder not working. power not being transfered to the shaft that turns the bobbin. how can i fix it?
    check the power cord to see if it plugged in to the machine correctly
    & if it is then something could be loose or broken inside, it needs to be serviced
    7helpful
    2answers
    My Tivoli Pal radio casing has a sticky feel on it, everywhere...how does one clean this or make it non - sticky
    Just cleaned mine this morning because it was so ridiculously sticky and dirty with great success with nail polish remover and cotton pads. Read this solution posted elsewhere but was worried about ruining the finish, and there are warnings on the bottle about not using it on plastics......but tried a bit on the back. Went very well and with a load of pads and alot of scrubbing, it came completely clean! No sticky residue left, no discolouration. Looks brand new!
    Rubber casing of lens gummy;difficult to extend or shorten lens
    did the lens get hot (closed in hot car)?- probably melted some of internal lubricant and /or adhesive on rubber rings or caused the rubber ring itself to start to deteriorate
    7helpful
    Case is "sticky" like glue
    The same thing happened with my old Praktica Sport Zoom binoculars, and (in my case) found that the sticky coating could be removed by repeated rubbing with paper towels moistened with methylated spirit ("meths"). SAFETY FIRST: If you decide to try this method and have not used meths before, it is a very flammable liquid, and harmful by touch and inhalation, so please wear rubber gloves and do this outdoors or in a well ventilated place and away from sources of heat or fire. That said, it is cheap and readily available from DIY stores, usually in their painting section.
    May 09, 2009 • Optics
    1helpful
    2answers
    The rubber armoring is "melting" or getting all sticky
    It can be easily resolve, just go to the youtude, check for sticky melting solution. The sticky surface can be treated and back to normal.
    5helpful
    3answers
    Rubber Grip Has Developed "Sticky Spots"
    The best and cheapest way I have found is to use 91% isopropyl (rubbing) alcohol...put a little on a paper towel, cloth, or cotton swab and rub the stick stuff off. I would also suggest putting on rubber gloves to keep the black stuff off your hands. Have fun.
    Top Praktica Optics Experts
    ADMIN Andrew
    ADMIN Andrew
    Tony Parsons
    Tony Parsons
    Are you a Praktica Optic Expert? Answer questions, earn points and help others
