SOURCE: dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
SOURCE: How to clean Dirt Devil Easy Steamer Deluxe Carpet
You can download manual here:
See page 9
http://www.dirtdevil.com/CustomerService/Manuals/DirtDevilManual.aspx?ManID=8fac8b06-4ad7-49a7-ac82-6f608a77a3bb
Please leave positive feedback if I have helped you
Thankyou
SOURCE: Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
SOURCE: can you clean carpet with dirt devil floor keeper
Refer to http://www.dirtdevil.com/products/details.aspx?id=MCE5500 for the manual.
From the looks of the manual it's just for flat floor surfaces (vinyl, lino, tiles, etc).
SOURCE: I need a manual for a Dirt Devil Vision Easy
You can get the manual on the link below.
http://static.highspeedbackbone.net/pdf/Dirt-Devil_MCE7350_Manual.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
