RCA HD52W59 HDTV Projection Television Logo
Posted on Jan 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a TEAC Tv, N533 Black colour that its power board got blown up.When i opened the unit, i discovered that the power board got burnt beneath. I saw an IC with 8 pin (DIP) labelled U1, very close to the 100uf capacitor that was burnt.Can you give me the details of the IC part no and its equivalent ?
Level 3:
  • RCA Master 19,187 Answers
  • Posted on Jan 09, 2018
RCA Master
Level 3:
Answers
19187
Questions
0
Helped
4345036
Points
82261
Are you sure about the make and model number?
5 Related Answers
Anonymous
  • 1030 Answers
  • Posted on Dec 17, 2007
SOURCE: Capacitor
u have to get the yx number of the back.. model d52w10 and then it ussally has something like yx1 next to it. then the board you need is a deflection board. not easy to replace.. depending on the model they can be as much as 350 or as little as 50.
Anonymous
  • 2920 Answers
  • Posted on Sep 03, 2008
SOURCE: Which board is it?
tell me what your tv is doing and ill try to go through everything with you on it
asnowman
John Snow
  • 788 Answers
  • Posted on Sep 04, 2009
SOURCE: 52" rca hd proj. tv model # d52w23
Your symptom sounds like a damaged convergence IC, whick you have found to be true.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
You will also want to replace the white heat sink2.gif compound that is on the heat sink2.gif, just scrape it off, then clean the surface with alcohol. Then apply a thin coating of fresh heat sink compound, if you do not do this important step the new IC's will not last long as the old compound will act as an insulator to the heat transfer.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Anonymous
  • 192 Answers
  • Posted on Aug 17, 2010
SOURCE: i have a 61 inch
the IC is your problem..because it is not compatible with the system unit..try to find a secondhand IC with the same value...and try to used it..
Anonymous
  • 1030 Answers
  • Posted on Aug 23, 2010
SOURCE: RCA D40W20 TV, washed out vidoe, no colour from
the fact that you have color on menu. is an idication this will be a small signal board issue.
Teac n533 12v LED/TCD DIGITALT/V
First; try blowing into the DVD reader, sometimes it is just a hair. also try a DVD cleaner disc. Check if the drive spins up correctly, and "listen". If it's spnning but having trouble reading you will hear a whizzing sound as it tries different speeds.
Panasonic lcd tv txp50u10b 220-240v no power
hi this may be down the fuse inside could have blown, glass type where the ac plug wires come in and are connected to the power boards metal holder if it's black in colour it's blown, but beware if you replace it and it blows again then there a dead short on the power board somewhere hope it helps
regards
shaun
120V tv accidentally connected to 240V
You most likely burned the capacitors on your power board, hopefully the overcharge did noy reach your audio visual connection bord. You will have to open the unit while it is disconnected from the power source and look for evidence of brown or black edgings around the various board components.
Smell the board if it smells like burnt plastic or wire you have blown the board or boards
If the TV is out of warranty, the cost of repair can be as high as $500+
Good Look. Ed Pinero
No power to Teac-MC-DX220i
it seems you power unit of mc-dx221 system got burnt just open your system and see the power unit
4helpful
2answers
There's no picture, the LED light just blinks, nothing.
I opened the power supply unit, and found two blown capacitors (swollen, and oozing black stuff) It is easy to fix, if you keep track of where the screws go, because there are so many.
1) open tv, and tape screws where they go
2) open power supply unit, and check if any capacitors are swollen, and oozing black junk, even if its just a litte
3) if you find blown capacitors, look on the back of the board, and find out what hole, or socket the leads go into, they all have a number.
4) with a DEsoldering gun, remove the solder from back of board, its easy, trust me. I'm no tv repair man, but even I could do it.
5) write down how many microfarads the capcitor(s) are, and the corresponding hole number.
6) find replacement capacitors online, and solder back into psu
7) re assemble tv, and enjoy.
My zenith big screen tv won't come on model pvr5263dt
Hi
Thanks for using FixYa. This might have happened due to over-voltage. Please check the power supply unit for swollen capacitors and burnt wires/components on the power supply board of your TV. You should try and turn off the TV for 8-10 hours to reset it. This issue might have occurred due to blown pico fuses located on the D-Board or due to blown fuse on the power supply board.
Please do rate the solution & revert for further assistance.
Thanks
Rylee
1helpful
No power!
okay, this seems like either the fuse hase blown in the actual mains plug, or the mass fuse inside the device, it looks like this very small glass fuse, same size as an ordinary fuse, its just seethrough. see if you can get a replacement for it, you may need 2 open the unit to check if it has blown, it will be black or a "burnt" colour from inside! if you dont want to open it, take it to any electronics store, they are bound to check for you, but these fuses don't cost more that $1 or 50pence!
hope this helps
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
