1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Take the lamp cover back off. Check the mechanism that the projector uses to sense the door. It might be a small pressure switch. Check whatever triggers the mechanisms is still attached to the door and hasn't broken off.
Have a good day!
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
Remove the lamp and reseat it carefully, following the instructions in the user manual.
If this doesn't help you may find that you need a new lamp.. if you are in the UK you can purchase a Sony VPL-EX5 Lamp here or from here if you are in the USA
