All universal remote controls should have to setup with the TV by its codes. There are codes, given below, to synchronize the TV with remote control. Brand name of the remote control you have isn't matter. Check these codes. Proceedings also is given. If you want further details, check this link, and select the site 'Electro-help'. pull up older posts there for more details. Setup codes for Toshiba TV are: 0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117
0141
Direct Code Entry
Press and hold the SETUP button until the red indicator stays on, then
release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator
blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry,
the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further
programming is required. Note: If some buttons do not operate your device, try
one of the other codes for your brand.
Need 5 digit codes for Direct TV remote, not 3 digit. I have a RCA flat screen and tried all 16 codes as per instruction from online PDF manuel and none of them work for me either.
remote codes are set by the manufacurer of the remote not the tv. if there are any others not listed in instructions for remote, the manufacturer of remote would have them. most combo unit are not able to be programmed into universal remotes due to the fact that there are alot of specialized function buttons on original remote. you can obtain a replacement remote thru toshiba
The TV code for a remote is set by the remote manufacturer and not by the TV manufacturer. You'll need to check the remote manufacturer's website for a list of codes. Or get a new remote control which will have the list of codes with it.
Have you tried these codes?
Code 1000 for Toshiba TV
Code 1048 for Toshiba TV
Code 1072 for Toshiba TV
Code 1105 for Toshiba TV
Code 1109 for Toshiba TV
Code 1118 for Toshiba TV
Code 1160 for Toshiba TV
Code 1190 for Toshiba TV
Code 1241 for Toshiba TV
Hi Had the same problem but found a similar looking remote for the SDV593SU online and the codes work! http://tv.manualsonline.com/manuals/mfg/toshiba/sdv593su.html
