Http://www.opendrivers.com/categorycompany/17/11246/soundcard-genius-free-driver-download.html
There are 21 Genius Soundcard drivers and firmwares. The updated drivers and firmwares are listed for Genius Soundcard devices. The drivers and firmwares may be different based on the device models and operating systems. Some drivers and firmwares can be installed in different operating system, such as Mac OS or Windows.
hope this helps
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
