SOURCE: Frigidaire Sid eby Side
sounds like a "performance problem" try pressing and holding the reset button for 3 seconds.
SOURCE: Frigidaire Gallery Side by Side - Fridge not cooling
Locate the defrost timer and rotate the dial a small amount clockwise. If the compressor starts the timer should be replaced. If the compressor does not start check the temperature control. It may be bad, if it is bad try jumpering the thermostat wires. If it starts and runs the thermostat is bad. Replace the thermostat.
SOURCE: Frigidaire side by side fridge
Power to compressor must be off (about 5 minutes) before a restart should be tried. Some of these relays are thermal and must cool down before power is reapplied.
SOURCE: Problems with Frigidaire Refrigerator not cooling
In turning it off you may have only closed the air damper. Set it to 1/2 way.
If ice or frost in the air damper area on refrigerator side you may not be defrosting the freezer coil.
Inspect from bottom looking up with a mirror and flashlight. You should have no Ice buildup frost that is even and white is normal. Feel Check the back wall mid way down to 1/4 way to bottom. Push on the wall slightly. Crunching like frost or snow behind wall is not normal. I suspect non defrosting here.
Next eliminate the inside fan motor. It has to run to push air all over
the freezer and refrigerator. If this fan doesn't run the results will
be only the area with the refrigeration evaporator coil will cool and it may get too cold and resemble a non defrosting situation where the air is not able to circulate because of frost build up.
Next eliminate the Ice maker and light as a source of heat. Unscrew and unplug them
Next eliminate the door gaskets from not sealing. A piece of paper set tween the door and frame and pulled across it and you feel resistance all the way and the gaskets are smooth and not warped they are OK
Next inspect the condenser fan and coil by the compressor underneath. A dirty coil here will cause diminished heat removal and possible for a partial cooling of some of the freezer.
Only after inspecting all these items and determining they are OK should you proceed with refrigerant checking. Also a person with out the ability to measure the actual amount of refrigerant being put in should be shown the door. Even with topping off (adding some) refrigerant I use a scale to determine that I do not put in too much. So if you have a friend that does this and no way to tell how much is too much.... well with all due respect your getting what you pay for.
If this helps you understand your problem and need more information please post back, I will follow up. If it helped you determine your trouble please rate me as high as you can. Thank You for using fixya and good luck.
SOURCE: Frigidaire side by side fridge/freezer
Try checking the evaporator fan. The blades are just pushed on and sometimes may work itself up or down and plastic fan could be rubbing.
Hello erintu81 - SY CF typically indicates that the refrigerator has detected a communication failure after power up. The wiring between the main control board and user interface board will need to be accurately diagnosis. Depending on the results either or will need replacing. At this point, I strongly recommend connecting a professional to move forward accurately and to properly assist with the repair(s).
