Door Ajar Warning Chime
The door ajar warning chime warns that a door is ajar. The door ajar warning chime is a single chime with a 1 second duration. The door ajar chime sounds when the driver or passenger door becomes ajar while the ignition switch is in the ON position.
The door ajar warning chime inputs are:
Chances are one or more resistors in the unit have come unsoldered from the board.
Easy fix if you have the resistors in the unit still, if not a quick trip to radio shack / local electronics store to get replacements.
This is a superDuty console that I did not too long ago.
F150online.com has a thread in the How To forum on the resistors for the F150 line, which is slightly different, and the resistors are a lower value than the SuperDuty version.
Do you mean nothing works or just the power lead? If nothing works I would check the ground. If just the power lead doesn't work on the I know on the older superdutys the large fuses had to be installed in the fuse box under the hood to make it work. They were usually in the bag with the trailer brake controller wiring and had directions on where they went. Hope it helps
check the ignition fuse.the glow plugs need to be on or the engine will not start.
there are many systems on that truck and it should be left to a mechanic with a scan tool.
there are far too many systems to mess around with.
