Click here sir
there select range/stove/oven
in that select switch
after doing that see for the 3rd part.
this is the light switch you need.
replacing it is not very tough. but it is not that easy also.
since you are going to work near circuit boards this must be done carefully. if any small mistake will cause more problems.
everything depends upon your expertise sir.
thank you
How can I find a schematic for the touchpad of a Dacor MCS-130 wall oven? I will need a schematic in order to replace the switch properly. I also want to confirm that the indicated part is correct, as the Parts place quoted me an entirely different part. Also, I want to see if it is simpler just to replace the entire Touchpad, and what the price differential would be.
Thanks.
