Hi gentlemen , would you please help me for solving my car problem ? my car ford expidition 2006 amarican and i use it in saudia arabia 1- l am getting ( check electronic throtile control ) alarm and stopped the car what is the reason ? 2- which best for using gasolen 91 or 95 in saudia arabia ? thanks & best regards
This issue usually occurs when the vehicle is between 60 - 70 mph. There is no official solution to this issue, it should have been a Ford recall, as this fault is dangerous.
There is a known malfunction in the fly by wire system that is suspected to be the cause of this system failure. The throttle body assembly gets replaced when this occurs as a possible solution to the problem. Check
the connections on the 2 tps sensors first before assuming the
replacement is necessary.
