Question about Takara Tomy Transformers Robo-q Rc Optimus Prime
I have purchased new robo q optimus prime. when i tried to play it won't move or no 'life' sign. i thought it's battery need to be charged. but when i tried to, it won't to be charged. the indication lamps (in remote) suddenly off... after that, this thing still won't move untill now. would you fix this problem? thank you. don
    Top Expert:
  • Takara Master
  • 52,421 Answers
If the battery doesn't charge, it may have to be replaced.
Posted on Oct 05, 2017
SOURCE:
Robo sweeper
ARE THEY CLOGGED AROUND WHEELS WITH HAIR ,AND TRY SOME W D FORTY OIL ,
Apr 09, 2013 | As Seen On TV Robo Sweeper
My robo kleen moves around the pool but has no suction so it won't pick up any debris
i had that problem, past year
open the motor check for rust stains on the round magnetic surface
i used a steel or copper brillo pad dry to sand down the surface
careful with those plastic motor screw washers to secure motor
Jul 27, 2012 | Smartpool Dolphin Robo - Kleen Above...
My 2005 xb won't start and when you put your foot on the brake it is tight and won't move
The tightness of the brake is normal. as the servo doesn't work until you run the engine. It could still be the battery as the radio only takes a small amount of power, whereas the rngine needs a lot more, get it checked by an electrician.
May 19, 2012 | 2005 Scion xB
Sony laptop dead problem
Could be many things. Let start with a couple of easy ones.1) Unplug charger from computer and outlet, take battery out press power for at least 30 sec. Plug every thing back power on. 2) charger bad won't turn on or charge battery, try diferent charger if don' know how to use a voltmeter. 3) power jack loose or broken. 4) last and worst mother board circuits transitors etc... btw processor, video card or input devices fried. Buy new board from ebay. Don,t fix it. Not worth it. This is Only if laptop gives completely sign of not turning at all. No lights, no hardrive or no working or fan. No signal of life. If couple of lights do turn on it can be the ram or video card, play with ram a bit. Good luck.
Dec 09, 2011 | Computers & Internet
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
It doesnt want to statr!!
you did change the batteries, im assuming?
if so, try connecting it to the computer with the USB cable. im not sure if that will do anything, but anything is worth a shot, right?
Feb 17, 2008 | Optimus DV-3040 Flash Media Camcorder
Takara Tomy Transformers Robo-q Rc Optimus Prime Logo
87 people viewed this question
Top Takara Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Takara Toy Expert? Answer questions, earn points and help others
