SOURCE: No power to track and/or train. Power to Holiday Express Train
Check the power circuit that goes to the track if there is an open circuit, open circuit means, break or cut line that can not flow the current going to the track to give a power to the train, ok.
Testimonial: "Thanks for your help. David"
SOURCE: Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
SOURCE: imaginarium instructions
On this page click under the picture where it says Assembly Instructions:
http://www.kidkraft.com/catalog/toys.asp...
I love train sets, have fun!
SOURCE: New Lionel Polar Express train set-up issue. The
My son just got this train and we are having the same problem. Taking the last car off solved the problem for us. I think it has something to do with accessories and the transformer voltage output (See page 14 and 15 of the instructions).
I have still not determined why it won't run with the final car but am assuming it has something to do with the lights on the cars pulling too many amps and not enough left to run the train. I will let you know if I find a solution. If anyone else knows how to solve the issue, any assistance would be greatly appreciated.
Thanks
SOURCE: need instruction manual for imaginarium
Do you still need this? If so, I have them but they are large and scanning them in will take some time.
