SOURCE: automatic transmission with tiptronic is
The transmission fluid needs to be replaced as well as the filter in the transmission. Solved my problem.
SOURCE: 91 Honda CRX Automatic Transmission Slips
I don't know much about cars, but I've got a service manual for your care in case you need one. It's BIG, 300mb.
Let me know if you need it.
SOURCE: 92 Accord Automatic shifting
Has anyone change the transmission fluid and used anything other than Honda ATF-Z1. If so, have the fluid/filter changed in this car and use only Honda Fluid. This is the only fluid that you can use in a Honda. Even if you have used the correct fluid an fluid/filter change may help. If that is not the case then I suggest you seek out a trusted professional.
SOURCE: Ford Escape Automatic Only Goes Into 1st Gear Manually
it sound like you have a vacum leak or your shifter cable may need adjusted
